01-24-2005, 09:04 PM | #1 |
5 Or 6 Speed Tranny With P.t.o??
HI GUYS.... I'VE GOT A TRANNY QUESTION FOR YA . I'VE GOT A 1969 1 TON TOWTRUCK, WITH A 350/SM465 COMBO. I'VE GOT A FRESH 396 TO DROP IN AS SOON AS THE WEATHER BREAKS, & I WOULD LIKE TO UPDATE THE TRANNY TOO, BUT I WOULD LIKE TO KEEP THE GRANNY GEAR AS IT COMES IN HANDY, & THE PTO CAPABUILITY IS A MUST FOR THE WINCH BUT WOUND OUT IN 4TH GEAR, IT FEELS LIKE YOU COULD SHIFT 1 OR 2 MORE TIMES. ANY SUGESTIONS ON WHAT TRUCK HAS THE KIND OF TRANNY I NEED.? JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
01-24-2005, 09:25 PM | #2 |
John,
They are kind of pricey but a Gear Vendors overdrive unit is an option. It will take the power and abuse. (Not that you abuse your wrecker!) Jim |
01-24-2005, 09:39 PM | #3 |
JIM-- YEP.. A GEAR/VENDORS UNIT WOULD WORK PERFECT FOR ME. TROUBLE IS THEY ARE A LITTLE SPENDY FOR ME. (AROUND $2400) I'D LIKE TO FIND A USED 5 OR 6 SPEED THAT I COULD USE FOR UNDER $1000 OR EVEN A GOOD USED GEAR/VENDORS UNIT. ANYBODY??? JOHN
01-24-2005, 09:52 PM | #4 |
junkyardjohn,
I would love to see a pic of your trans/PTO & how it all hooks together. I've always been curious to see what one actually looks like.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
01-24-2005, 09:57 PM | #5 |
My 67 ton here has the new process 4 spd with a spicer aux tranny . high and low range behind it,the old twin stick. I can get you pics of that if you want tommorow.. It has the pto plate on either side of the trans or the aux trans has 1 too. Its a really cool setup.. 1st one i have even seen...Erick
01-24-2005, 10:22 PM | #6 |
Watch out for your cornhole !
I have an NV4500 ( 5 speed ) in one truck and an NV5600 ( 6 speed ) in another truck. Both have the plates for PTO mounting.
You'd likely be happy with either of them if you find one you can buy for a fair price.
01-25-2005, 12:34 AM | #7 | |
(QUOTE)I dont think your current PTO's gear pattern will match up to the newer upgraded trannies...ask a dealer that installs such stuff. I'd bet not.(QUOTE) ROD -- I JUST HAPPEN TO HAVE A NEWER PTO TRANSMISSION . A GOOD PAL GAVE IT TO ME. I NEVER THOUGHT ABOUT THE CUT OF THE GEARS THOUGH, YOU'RE PROBABLY RIGHT. I WAS JUST GOING TO SWAP IT OUT CAUSE IT WAS 35 YEARS NEWER & LOOKED ABOUT 75 LBS LIGHTER. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST Last edited by junkyardjohn; 01-25-2005 at 12:54 AM. |
01-27-2005, 06:40 PM | #8 | |
01-25-2005, 12:27 AM | #9 |
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
01-25-2005, 01:12 AM | #10 |
There are a series of letters and number that mean something to certain pto people that know what there doing. Write en down and tell a PTO rebuild place they will know what the application is.
Code letters mean such things as stud pattern metric or standard, pto is self lubrication or needs to have fluid pumped to it, 2 way type, 1 way type, which direction the pto shaft faces, shaft high or low position, mechamism to activate the pto...it gets interesting if you get someone to supply you a few pages from an old book or new book.
01-25-2005, 07:30 PM | #11 |
John--- Don't worry about the pto. Whatever tranny you get I can get you a pto for. As long as it has the provision for one.
68 short fleet with 71 front clip 2wd jaguar blue 99 chevy ext cab shrtbed z71 loaded 99 chevy swb fleetside(daily driver) Sparks, Nevada |
01-25-2005, 08:08 PM | #12 |
GREAT JIM.. IN THAT CASE I GUESS I HAVE NO EXCUSE AT ALL, BUT TO PUT A 5 OR 6 SPEED IN. WELL I JUST KEEP ADDING TO THE WORK TO BE DONE ON THAT OLD TOWTRUCK. A COMPLETE 85 DISC BRAKE FRONTEND , A BIG BLOCK & NOW A NEW TRANNY & A NEW PTO. NOW TO GO ON THE HUNT FOR A NV5600 OR EVEN A NV4500 , BUT I WOULD RATHER GET THE 6 SPEED. THANKS TONS.. JOHN
01-25-2005, 08:24 PM | #13 |
Fabricate till you "puke"
Overdrive dont come easy , if you are drivin a stick truck! IMO , that 4 spd you have is pretty d@mn tough.....spend the buck, & add the Vendors(pretty much bullet proof combo).....if you have to do her twice, it will cost you just one old mans point of veiw. best of luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-26-2005, 09:55 AM | #14 |
I'd like to know what you eventually come up with also...wouldn't mind a 5 or 6 speed in my 72 tow truck either.
01-26-2005, 10:28 AM | #15 |
Never enough time!!
The 6 speed is great for towing, always keeping the motor in its peak rpm range, but if you don't tow alot, get a 5 speed. Granny gear and OD are about the same in both but with the 6 you have an extra gear. I have a 6 in my 2001 HD with an 8.1, works great on the trailer...alot of shifting when not. I would think it would be great on the wrecker though John, good luck in the hunt for one!
01-26-2005, 12:41 PM | #16 |
THANKS GUYS. ANYBODY GOT A NV5600 LAYING AROUND, THAT THEY ARE WILLING TO PART WITH???? JOHN AT FK9U812@AOL.COM
01-26-2005, 03:22 PM | #17 |
the NV5600 is a dodge-only transmission, so check on ebay, a dodge forum, or a tranny shop. the 6 speed that GM uses is the ZF S6 650, which Ford also uses.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
01-27-2005, 12:43 PM | #18 |
When I went to install a pto onto the Allison Auto in my 85 GMC 2ton I got the one I needed from a local place that services big trucks and builds beds (Benson Truck Bodies). I have seen straight cut gears and angle cut gears on the pto units. I think that the bolt pattern is common to be 6 bolt pattern. It should be on most trannies light duty and medium duty. The bigger bolt pattern should only be on the big semi type trannies. A neighbor gave me a pto that is 2-speed. I've never seen one before. What would a 2-speed pto be used for?
01-27-2005, 01:28 PM | #19 |
GEARHEAD
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
01-27-2005, 05:15 PM | #20 | |
01-27-2005, 05:51 PM | #21 |
I'll have to look at it again, but I thought it turned the same direction just faster or slower depending on the gear. A forward and reverse makes sense for a pto winch. If you used the 2-speed to drive a hyd pump wouldn't the pump just put out more volume therefor making the equipment that the hyd pump is running (hyd winch or a cylinder) move faster. If I can find it I'll get a pic.
01-27-2005, 06:25 PM | #22 |
Saving 1 truck at a time!
How about an Eaton 2-speed rear axle? It was available in the 60 series trucks and would be really cool on your tow truck. It would up the capacity of the axle to 17,000 lb! I don't know if the gear ratio gets you there though but they were available on lots of the bigger Chev trucks and were electric shift.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
01-27-2005, 06:38 PM | #23 | |
01-28-2005, 08:12 AM | #24 |
John, negatory, it's behind a Cummins diesel in a Dodge.
01-28-2005, 01:10 PM | #25 |
only dodges got the NV5600...
