01-24-2005, 09:26 PM | #1 |
Here are some pics of the 427 in my 63
Here is a pic of the 427 i set down in my 63 yesterday.
Youth soon passes away, but immaturity can last a life time. Last edited by cochran63; 01-24-2005 at 10:56 PM. |
01-24-2005, 10:06 PM | #2 |
NO FAIR!!!! i want one!!
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
01-24-2005, 10:06 PM | #3 |
Did someone say MUD?
Nice looking motor you got there...Later Mike
Im in the market guys...so keep ya eyes peeled -------------------- Mini trucks are for guys who cant get it up! |
01-24-2005, 10:26 PM | #4 |
Professional Grade
:drool:
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-25-2005, 01:27 AM | #5 |
Niiice. Not to steal the thread but my family owns a farm and one of our grain trucks burned up this fall, it had a 427 in it. I guess the carb and intake melted together, is that motor worth anything? I haven't seen it first hand but the starter was what started the fire, I assume it didn't do too much damage to the block and heads but haven't seen it yet. My uncle is trying to get rid of it....What do you think?
Ben 84 C10 Silverado 14 Silverado Z71 |
01-26-2005, 06:53 PM | #6 |
You might have to ask a more knowledgeable big block guy about that. This is my first experience with a big block.
Youth soon passes away, but immaturity can last a life time. |
01-26-2005, 10:06 PM | #7 | |
paper or plastic?
BTW your motor looks great
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
01-26-2005, 11:27 PM | #8 | |
01-27-2005, 03:18 AM | #9 |
Oh Look Out!
Dan's Webshots "I have a lot of growing up to do... I realized that the other day inside my fort" - Zack Galifianakis. |
01-27-2005, 11:19 AM | #10 | |
paper or plastic?
I got a herbert Hydro roller, little smaller too. I would have used the comp but I did not go with the 496 stroker I just had it bored 30 over 461CU
01-27-2005, 01:28 PM | #11 |
Professional Beer Tester
Not to rain on anyone's parade, but a truck 427 is not the same as a car 427. They are big blocks, but they are made especially for heavy-duty use, much like the 366 truck engine. They are very strong engines, designed for low rpm and high-torque. They have smaller intake valves and sodium-filled exaust valves, 4-ring pistons and the very early ones had timing gears instead of a chain. I have also been told that they have a taller deck height than a passenger 427, but I cannot confirm this. If it is true, then passenger intake manifolds would not fit without decking the block. They will fit regular Chevy mounts, just like any other small or big block, and regular flywheels should fit too. I guess somebody could build one up, but it might cost alot more than a car engine.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
01-27-2005, 10:31 AM | #12 |
Get the motor out. have it rebuild while it's out I'm sure the insides are fine the coolant and oil would have kept it from harming anything other than gaskets. If you don't want it ship it out my way I'll buy it.
01-27-2005, 05:49 PM | #13 |
you can get intake spacers for the tall deck 427
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
01-28-2005, 12:29 PM | #14 |
I think I have to agree with 60-66 Nut. From what I understand the truck block is different than the passanger vehicle block. Taller deck.
Not to say that you couldn't put one in your truck...might fit. But you wouldn't be able to swap heads / intake off a car block.
'72 Chevy K-20 Crate 350, SM465, 4.10's |
01-28-2005, 02:12 PM | #15 | |
DAMN, I love Big Blocks!
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. |
01-28-2005, 02:56 PM | #16 |
I figured the heads would fit, but I didn't know anybody made the intake spacers, cool. The truck intakes are 4 bbl, but they are very big and heavy. Then they have a dual-thermostat housing with about a 2 1/2" water outlet and the by-pass outlet is about 1 1/2", so it would be hard to use the passenger water pump. I wonder if they make special pistons, or if you have to use the tall-deck 4 ring pistons. Regular 427 pistons would probably fit(same bore) but they wouldn't reach the top of the deck, unless the truck uses longer rods.
60-66 Nut
01-28-2005, 04:44 PM | #17 |
what about 454s? are they different between car and truck (light duty, up to one ton). Thank you!!
01-28-2005, 08:30 PM | #18 |
Pretty much. The early car 454's (70-74) were much higher performance than the ones they started putting in the trucks later on. But basically, the truck engines were the same up to one ton. We had about 60 Chevy 454 Doolys from 76' thru 79' models that we used to pull beverage-body gooseneck trailers for nearly 20 years. In that time, we rebuilt or replaced many of the engines, and I think only the early ones were four bolt mains, the later ones were all two bolt. The 79' engines had smaller intake ports.
60-66 Nut
01-29-2005, 12:31 AM | #19 |
our 3/4 ton 77 block what a 2 bolt block, but it had the 7180 heads, so alls good.
01-29-2005, 12:44 AM | #20 |
AUSTIN TX
very nice motor. wish mine looked like that one.
