Old 01-29-2005, 07:55 PM   #1
shortymac83
hmm...
shortymac83's Avatar
proper way to drop a truck...
Okay, I'd like to do about a 4/6" drop on my 67 once I start tearing into it. What is the proper way to do this? What parts do I need, and where can I get the parts? Also, what is the way to properly set up drivetrain geometry? This is a 2 piece driveshaft style truck.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 01-29-2005, 08:36 PM   #2
powell72
powell72's Avatar
6'' drop spring in the back(or 4'' and 2'' block) with longer adjustable panhard bar, shocks and shock mount relocators. Assuming you are going to discs in the front, 1.5'' or 2'' spring with drop spindles and shocks. A lot of us buy from Early Classic Enterprises. Geometry is already built into parts, just need aligned when done.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-29-2005, 09:06 PM   #3
David Johnson
David Johnson's Avatar
The Early Classics Enterprises kits are great. I can't say enough good about the quality and ease of their kits. Also, I would recommend calling them with your questions, they also build these trucks and are very knowledgable. Everything you need will be in a kit.
David Johnson is offline   Reply With Quote
Old 01-29-2005, 09:59 PM   #4
GSFMECH
On the road
GSFMECH's Avatar
This is the Early Classic 4/6 drop kit with TT 11's 245 and 275 x15 60's. Their websight is great.
Mike
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 01-29-2005, 10:50 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You will not find better parts or service than Early Classic.
I did a full 4/6 drop on my stepside last year and documented the whole thing with pictures here on the board.
When you order ECE stuff, you get it all. No need to run around trying to round up little widgets and such. They include all you need. Just take the box out to the garage and get to work.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-30-2005, 01:10 PM   #6
shortymac83
hmm...
I'm staying with the drums and I6, but I don't want it to be jacked up like it would be if I redid the suspension stock. The I6 is going to be built, so never fear, but I just wanted it to look a bit better in respect to the suspension and ride height.
Old 01-30-2005, 06:30 PM   #7
FirstGen
Just Don't Stop!
FirstGen's Avatar
I'll sell you my, 4/6 drop springs only 6 months old for $180 shipped.
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 01-30-2005, 10:32 PM   #8
shortymac83
hmm...
I have easy access to the springs and shocks, I was wondering about the proper way to drop the front though, because I don't want my wheels to look like this / \ as I go down the road. actually, maybe just a 2/4 would work, but the suspension is ancient, so it might already have a 2/4 drop (sagging springs), so who knows...
