Old 01-30-2005, 10:43 AM   #1
saxmo
saxmo's Avatar
Thumbs up ford 9" rearend direct swap?
Hey guys. Just looking for some confirmation here. I was told recently (yesterday), that the rearend from a 1978-1983 Lincoln Mark V would swap right in to one of our trucks ( I have a 69). I was also told that this is a disk rear from the factory, and it has the 5 on 5 pattern like our Chevy's. I spoke with someone who said that he had done it, and all he had to do was get brackets welded on to his frame for the leaf springs. He said that there was a 1/2" difference in the width, but he made it up in wheel backspacing. He also changed the gears in the center chunk, because the town car was too tall. He said total out of pocket was about $500 to go Ford 9", rear discs, and matching bolt pattern! Is this too good to be true? Has anyone else heard of this crossover? Thanks
2004 Corvette Coupe Black LS1 (daily driver)
1973 Ford Bronco (resto/mod @ 95%)
1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said)
1997 Ford F150 4.2L 500k+ miles (trash hauler)
2011 Nissan Juke (wife's daily driver)
1943 Ford GPW WWII jeep (waiting its' turn)
saxmo is offline   Reply With Quote
Old 01-30-2005, 11:10 AM   #2
Randy70C-10
Randy70C-10's Avatar
The U-joints are different, I don't know about the bolt pattern though.
Randy70C-10 is offline   Reply With Quote
Old 01-30-2005, 11:36 AM   #3
zooza
do a search, i think i saw one recently about such a swap. and there are several problems with the swap. I dont know how to link ,but maybe youll find it its there!
zooza is offline   Reply With Quote
Old 01-30-2005, 12:49 PM   #4
StingRay
StingRay's Avatar
Thre bolt pattern is correct but as said u-joints and driveshaft length will be issues as will mounting pads and a panhard mount if a coil truck. It is by no means a DIRECT swap.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 01-30-2005, 01:26 PM   #5
junkyardjohn
junkyardjohn's Avatar
I'VE GOT A 9" OUT OF A 75 LINCOLN MARKIV. IT'S ABOUT 1 3/4 WIDER THAN A 12 BOLT (NO BIGGIE). IT HAS A 5 ON 5 BOLT PATTERN JUST LIKE OUR TRUCKS & YOU ALSO GET DISC BRAKES. I GOT MINE FROM A BONEYARD FOR AROUND $100. I THEN TOOK IT TO A FRIEND WHO OWNS A DRIVELINE SHOP, & SWAPPED A BUNCH OF PARTS TO HAVE HIM COMPLETELY GO THRU IT WITH ALL NEW BEARINGS AND SEALS, NEW RING & PINION, (WENT WITH 355-1 GEARS) & A BRAND NEW POSI UNIT. IT'S GOING IN MY ONGOING PROJECT , AND I CAN'T WAIT TO GET IT UNDER THERE. I JUST ORDERED PERCHES FRIDAY TO WELD ONTO THE REAR END & BOLT TO THE TRAILING ARMS. AS FAR AS A PANHARD BAR, I CUT THE BRACKET OFF OF A EARLY 60s TRUCK. THEY ARE ON THE AXEL TUBE INSTEAD OF THE PUMKIN LIKE OURS. I'VE GOT AN ADJUSTABLE PANHARD BAR. THE $500 PRICE TAG IS PROBABLY PRETTY CLOSE FOR THE INITIAL COST + THE RING & PINION SWAP. TO GO THRU IT COMPLETELY, WITH A NEW POSI UNIT IS PROBABLY MORE LIKE $1000-$1200 BUT YOU'LL HAVE A BULLET PROOF REAR END, THAT YOU CAN SWAP FROM TRUCK TO TRUCK AS YOU CHANGE DAILY DRIVERS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-30-2005, 02:34 PM   #6
saxmo
saxmo's Avatar
That seems like a cheaper way to go vs. the aftermarket. IMO
Old 01-30-2005, 03:15 PM   #7
junkyardjohn
I THINK IT WOULD PROBABLY BE ABOUT THE SAME PRICE, BY THE TIME YOU BOUGHT A DISC KIT, ROTORS & CALIPERS. BUT IF YOU WENT WITH THE 9" , AT LEAST YOUD HAVE A REAR END THAT WOULD STAND UP TO ANY MOTOR YOU USE. JOHN
junkyardjohn
DON'T RENT U-HAUL
Old 01-30-2005, 05:57 PM   #8
saxmo
saxmo's Avatar
I thought the mark V already was a disc setup?
Old 01-30-2005, 06:14 PM   #9
cableguy0
it is already a disk rear but your not going to want to use the cruddy calipers with dried up seals and rotors that are most likely rusted and pitted bad not to mention dry rotted brake hoses
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
