Old 01-30-2005, 01:28 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
? for big Block Builders, Need quick answer
Have any of you guys that build Big Block Chevy ever heard of drilling small holes in the oil gallery plugs in the front of the motor , behind the timing chain, so as not to form an air pocket and not oil the front lifters ????
I'm helping a guy do his motor and his machinist recommended this.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 01-30-2005, 01:35 PM   #2
jhow66
jhow66's Avatar
Very small holes to oil the timing chain better.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-30-2005, 03:49 PM   #3
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
I drilled one hole .080 in the center plug. To remove air and send more oil to the gear drive.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 01-30-2005, 11:24 PM   #4
bagged91
Out draggin'
bagged91's Avatar
I would be interested in learning a little more about this too. I plan on running a gear drive on my 454 and a little more oil wouldn't hurt....
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 01-31-2005, 12:29 AM   #5
sniper2321
sniper2321's Avatar
what was previously said is true for the oilling part not so much for the air in the oil. its main jod was to let oil be sprayed on the thrust washer for thr camshaft. I like to use a .06 to .07 on the top middle oil plug.
sniper2321 is offline   Reply With Quote
Old 01-31-2005, 10:53 AM   #6
1970 CST Short Wide
Senior Moment
Talking to another machinist and he said it would not allow the lifters to pump up if you drill to big. This is our major concern. I did not do it on my recent BB build and I have no problems and neither of us are running gear drive.
Pittsburg Ca
94565
Old 02-01-2005, 12:00 AM   #7
Jeff M.
Jeff M.'s Avatar
I've drilled several plugs on big blocks. On my old 402 as stock occasionally the lifters would tick a bit. Never have that on the one's we have drilled. That little mod has been around for a long time.
69 C-10 CST Short Fleet, Factory Air, BB427-400 Auto-2400 stall-tilt-cruise-Tach & Vac Gagues, 4/6 drop, power one piece side windows, Eaton posi.
Jeff M. is offline   Reply With Quote
Old 02-01-2005, 10:12 AM   #8
arkracing
Weekend Warrior
just get a timing chain that has the roller bearing plate that rest against the block inbetween the cam gear and the block. I got mine from Manley as a complete kit with the, chain, rollerbearing, and thrust button. for $100.
PN# 73142 from Manley - SKU# 8 07298 01625 2
NO MACHINING REQUIRED WITH THIS SET UP
the main problem with big blocks is that the cam gear rides agains the block and wears the block out. - then you have to have it machined to accept a different type of roller bearing.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
