01-31-2005, 12:15 AM | #1 |
ureckmefixit2@cox.net
Before And After ( Not Finished Yet )
I started with a truck that was so dirty it was black. 400SBC TH350 Locked up rear end I'll show some pics of after washing 5 times more after 10 washings.
01-31-2005, 12:18 AM | #2 |
I'm not done, long ways to go. What do you think.
01-31-2005, 12:26 AM | #3 |
laying low
You did a bit more than just wash it! LOL
01-31-2005, 12:42 AM | #4 |
Super Job!! It looks like mine, except mine is a long bed. What year is your truck?
01-31-2005, 01:06 AM | #5 |
73 Chevy 406CID 305 58cc heads 194 150 Valves 268H Comp Cam 2500 Stall. 373 Gears and still look'n for more stuff to put in. Matt
01-31-2005, 02:53 AM | #6 |
Project 2 Resume
Nice job. I caught the valve cover trick. Just curious which heads (casting numbers) you used to support that 406? Are they a set of the more common 081's or 191's?
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
01-31-2005, 04:22 AM | #7 |
I dont remember the cast # I got the heads from a low Hrs. Mercruser 5.0L HO moter. Ported big time 194 / 150 165cc runners. Any way there just temp. I have a set of Sportsman ll heads going on soon. When I get headers. Oh the new heads 2.02 1.60 64cc Angle plug 200cc runners. I got a deal on them
01-31-2005, 02:22 PM | #8 |
Project 2 Resume
Ok, probably 081's or equivalent. The 191's/193's (tbi swirl ports) are around 168cc in stock form. Should be nice with the upgrades.
02-01-2005, 06:15 AM | #9 |
I didn't use the swirl port heads my machinist said not to use them. The heads I have I did alot of bowl work and smothing bumps. They flow more then a stock 2.02 head even with the 1.94s that are in them. They screeeeem!
02-03-2005, 07:13 PM | #10 |
E.H.F.D Engine #2
hey i was wondering what you used to clean your engine compartment. i have some mud on my motor, and i used GUNK engine brite, and it looked great while it was wet, but then like 2 hours later when it dried, all the dirt was there again..... any ideas? thanks
-NICK '72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation '89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205 '15 Chevy 2500HD CCSB High Country Duramax '22 Tahoe Premier Duramax |
02-03-2005, 09:44 PM | #11 |
Castrol purple cleaner, comes in a gl. bottel at the parts store and a steam cleaner. Then I pulled the engine and had it vatted when I rebuilt it. Matt
02-07-2005, 12:14 AM | #12 |
How do you pass emissions with the 406? I am from Glendale and I am wanting to start an old chevy truck project But I am worried about passing emissions with a bigger cam and carb.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
02-07-2005, 12:35 AM | #13 |
If your running a Holley carb I'v got it down the other carbs.( no ) Im a little out of practice, This is my first hot rod in 20 years. I mostly ran Big Block Mopars and Fords. My Ford had a 538 lift 308 der cam, and a Holley DP and had no trouble passing the state tests. I would pull in the building and it would shake the hole place. The guys there took one look at the truck and said, It wont pass. They ate every word. I got a 1.28 out of a max 4.00 HC. As long as the carb is setup right,( no problem ) If you have any questions Email me at ureckmefix@cox.net Matt
02-07-2005, 07:51 AM | #14 |
Pick up man
thats a nice lookin truck man
