Old 01-31-2005, 01:01 PM   #1
Daubs
Daubs's Avatar
Q: put 80's 3/4 ton axle's under a 71 1/2 ton 4x4?
Still looking for the right 71-72 long box 4x4. May have a 71 1/2 ton 4x4...will see soon.
Wondering if anyone has taken the axles from an 80's 3/4 ton and put them under a 71-72 1/2 ton 4x4? Will the leaf springs bolt right on to the 71 mounts?
What issues did you run in to?
Thanks for the feedback guys. This board has been incredibly helpful to me. D.
'72 Chevy K-20 Crate 350, SM465, 4.10's
Daubs is offline   Reply With Quote
Old 01-31-2005, 03:14 PM   #2
1969 GMC
1969 GMC's Avatar
the front axle will bolt right up (at least the spring mounts...the shock mounts may be different), but the rear wont. a rear axle from a 1 ton would bolt right up, though.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-31-2005, 03:15 PM   #3
Yukon Jack
Yukon Jack's Avatar
If you try to use the front leaf springs they will be too long unless you change the mounting location on the 71-72 frame. The axle itself will have the proper spring pad width and location. The shock mounts are in the proper location also.
I don't know about the rear spring width. The spring pad placement on the rear axle will not work. You will need to remove the spring pads and weld them on in a different location - the width is different. Also, the shock mounts on the rear axle will be wrong. If you get a 1 ton rear end, the spring pads will be in the correct location.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-31-2005, 03:34 PM   #4
Mudder
Mudder's Avatar
You posted this same question over on the 4x4 board.
http://207.44.196.117/vboard/showthread.php3?t=138049
Mudder is offline   Reply With Quote
