painting interior plastics
what do you guys use to paint interior plastics? i would prefer something i can get local. do you use a special primer or anything? i want this to turn out good and not scratch off and look like junk, if ya know what i mean
thanks
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
Slots go on anything!
I am pretty sure Oreillys carries SEM brand trim paint. They should be able to get you the correct primer and dye for the plastic. Just make sure the surface is clean. I usually clean it with wax and grease remover first, then use lacquer thinner and a scotchbrite pad. Go back over it with the wax and grease remover to get off what you might have scared up with the lacquer thinner, prime, and paint.
1974 Jimmy- 5.3/4L80e/NP241 |
Oh,you can't buy that new
![]() Join Date: Apr 2000
what Jonboy said is fine and way better than the methods that some people try :-( . at Auto body supply houses they do sell PLASTIC PREP & VINYL PREP that should be sprayed on first and it is available in spray bombs. There are LOTS of other 'enhancing' products including special etching/flexible primers ,but you could wind up with $300 worth of stuff that you only needed a dab of. if you plan to do door panels and a lot of other pieces like dash pad & such you should consider that. DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. |
Signals in the bumper.
When I took my dash to an upolstery shop to get it dyed, all they used was SEM interior paint so that's what I have used ever since.
All of these...
Jeff C. 1981 Chevrolet Silverado - Under major construction...again. link 1962 Chevrolet Impala 4D Sedan moredoorclassics.com 1936 Ford Pickup - Frame-off in progress link 1979 Chevrolet Camper Special Flatbed link |
Happy to be here
![]() Join Date: Mar 2000
For the "do it yourselfer" SEM is the only way to go. Like Jonboy said the key to good adhesion is clean it, clean it, and clean it again. This can't be stressed enough. Adhesion promoter is good insurance too, just make sure you follow the directions on cure time....
FWIW, I dyed all of the interior plastics in my 81 El Camino using DuPont products, and it was tough as nails. The downside is it requires spray equipment. The cleaning would be the same, though. I have had good luck with the SEM stuff as well. I did manage to get high as a kite off of the adhesion promoter. That is some noxious stuff. They really mean use in a well ventilated area....
danoxyfumeshadnooaffectonme
Guys, don't laugh
