front CV joint question
I'm doing a rebuild of my front CV joint. The vehicle is a 72 K5 blazer and the centering yoke, h-member, weld yoke, and ujoints all say spicer. The ujoints measure out to be 1310s. The CV ujoints do not have grease zerks but the front differential does.
So here is my question. What spicer part numbers should I order? I need 3 new ujoints and a new centering yoke (whole assembly with ball, spring, dust shield, & needle bearings). These are the part numbers I found but I don't know if they're right. Ujoint 5-153x (quanity 3) Ball Centering Kit 211355x (quanity 1) The pin diameter of the spicer weld yoke is 0.485. I assume it is OK to put greasable ujoints in the CV unit. __________________ Regards, RLK 72 CST 4" Lift, 35" tires |
Hmm I never have rebuilt a CV but I assume if you use greasable Ujoints the zerk fittings may be in the way.??
Check with a local driveline shop for part # and such..oh nad stick with Spicer if you can ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
SKINNY TIRES RULE!
I think LMC lists the whole assembly in their catalog. Of course, they don't give real part numbers.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
