Old 02-08-2005, 04:30 PM   #1
Joe67
67 is sold
rear brace fabrication after tank install
I took these pics during the installation of my rear fuel cell this past weekend.
I'll remove it once It is properly located to clean up the frame appearance
I removed the rear brace support to clear the tank. I am considering the fabrication of another brace to go between the frame rails or can I just run without anything there?
I plan to run a rear roll pan so I am not concerned about the rear bumper brackets. Is there anything else I should be concerned about back there?
Thanks!
Joe
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 02-08-2005, 11:13 PM   #2
Low69CST
I would weld in a substancial (spelling?) brace back there. If you get rear ended, especially with a roll pan, you have zero protection around that tank. If it was my truck, something would be in there.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 02-08-2005, 11:20 PM   #3
70c10swb
no brain no headache
70c10swb's Avatar
hidden hitch maybe???
btw what fuel cell is that?
progress is looking good Joe
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 02-09-2005, 03:05 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Fab up a "C" channel of some sort.Maybe some 1"x4" boxed tubing or something.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 02-09-2005, 07:22 AM   #5
modifiedGMC
I used a chevy luv tank and mounted it under the rear. I had to remove the rear brace but I went back and built a hidden receiver hitch which basically replaced the brace.
modifiedGMC is offline   Reply With Quote
Old 02-09-2005, 08:23 AM   #6
Joe67
67 is sold
That is one of Mark's tanks (FuelCellGuy)
I am interested in putting something there for sure.
If memory serves from the teardown, I won't need any of those holes in the side of the frame for anything. Can I just box it in with no problems?
Does anyone have a link or a pic of a hidden hitch for these trucks?
Thanks.
Old 02-09-2005, 08:58 AM   #7
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Is that the 16 gal tank?
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 02-09-2005, 09:09 AM   #8
Joe67
67 is sold
I have the stats at home, but I believe it is a 17-18 gallon tank.
Old 02-09-2005, 09:19 AM   #9
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Looks good, I talked to mark other day about my tank just need a few more dollars, if you don'y mind could you tell me how far below the frame that's hanging. Thanks
Is it Sunday yet???
68 Project
Old 02-09-2005, 09:41 AM   #10
Joe67
67 is sold
Thanks.
I'll get the measurements and the other specs tonight
Old 02-09-2005, 07:36 PM   #11
Joe67
67 is sold
Texas 68 -
The tank hangs 3" below the bottom of the frame rail and 3.75" inside the rear of the frame rail.
I took a look at my notes, and I have the 7" 16 Gallon tank from Mark.
Old 02-10-2005, 08:03 AM   #12
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Originally Posted by 67c10step
Texas 68 -
Thanks, that's what I talked to him about for mine, I just need another payday or so to get my order in.
Is it Sunday yet???
68 Project
Old 02-10-2005, 10:20 AM   #13
BubbaGreen
Early Classic sells a bracket seperately for the tanks they sell, I think it goes for $45.oo, would most likey be perfect for what you want. Its posted on there website in the gastank section
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 02-10-2005, 10:27 AM   #14
Joe67
67 is sold
Good find! Thanks
It even has the rear harness hole there... $45 isn't bad either
Old 02-14-2005, 05:03 PM   #15
Joe67
67 is sold
Thanks again for the help, I just ordered the ECE brace
Old 02-14-2005, 05:43 PM   #16
Bowtiefreak
Bowtiefreak's Avatar
I was in the same situation as you and I ended up getting the rear brace from Dave at ECE also. Worked out great.
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 02-22-2005, 06:25 PM   #17
Joe67
67 is sold
The brace is here
Nice piece as usual from ECE. Now to prime/paint or have it Powder Coated to match the frame
