02-10-2005, 06:38 PM | #1 |
Tach on new distributorless ignitions??
How do you hook up a tach on a distributorless ingnition motor.....got a sand rail with a 98 ford 4 cylinder in it and was wondering how i hook up a tach...no distributor??? anyone done this??
Thanks Rick
https://www.ebay.com/itm/295742064443 |
02-10-2005, 07:09 PM | #2 |
OBS guy
You can use a magnetic pickup. Not sure of the implications, but I know this pickup can be used for the tach signal. Think it measures crank rotation by the harmonic balancer somewhere.
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
02-10-2005, 09:42 PM | #3 |
The Ford 2.3 in the Ranger gets it's rpm signal from the crankshaft position sensor to the computer ( PCM)
Ford calls this signal the PIP ( profile ignition pickup) The factory tachs in these pickups use a tach signal sent from the pcm to the gauge cluster. I'm not sure if an aftermarket tach would be able to operate properly using this same signal or not?
"Negative people always seem to have a problem for every solution" |
02-10-2005, 09:49 PM | #4 |
oops. I guess I didn't read your post very well. I thought you said you had a 4 cyl from a 98 Ford Pickup. Anyway, if it's from a car, the DIS ign systems all operate basically the same way.
02-11-2005, 11:11 AM | #5 |
it is from a pickup...where would the signal come out at?? would there be markings on the pcm??? does anyone have a diagram for this??
02-11-2005, 09:38 PM | #6 |
If you're using the original Ford wiring harness, The 104 pin connector that
goes into the PCM should have very small numbers on the back side that correspond to each pin. The tach signal wire out of the pcm is a tan wire with a violet stripe. It comes out of pin 48.
02-11-2005, 10:08 PM | #7 | |
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd |
02-11-2005, 11:36 PM | #8 |
Yea, I work on Fords for a living. I figure that a good doctor needs to be where the sickest patients are
02-12-2005, 11:06 AM | #9 | |
