Old 02-12-2005, 10:12 PM   #1
Gyva
Gyva's Avatar
Freaking light switch!!!!! lol please help...
so I'm down to sanding ant painting my dash and I'm trying to get the intrument panel off and I can't get the light switch disconnected or disassembled??? can someone give me the rundown on this well kept secret... (well for me it is)
Thanks Guys.... Rock On
Mike...
Gyva is offline   Reply With Quote
Old 02-12-2005, 10:28 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
There is a button on it to remove the knob. Sorry, don't remember if it is the top, bottom or side.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-12-2005, 10:34 PM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
top on the last one i took out !!!!!! top middle seams to me like
tnblazerk5 is offline   Reply With Quote
Old 02-12-2005, 10:36 PM   #4
Gyva
Gyva's Avatar
like a little button on some socket wrenches to remove the socket? thanks
Mike
Old 02-13-2005, 12:35 AM   #5
bouncytruck
SKINNY TIRES RULE!
Kind of, but it sticks up a little more. It has a spring under it that is visable once you get it out. If you have an LMC catalog, take a look at the illustration.
bouncytruck 1972 K5
Old 02-13-2005, 05:09 AM   #6
donkey69
JB-80 "Twice as Good"
donkey69's Avatar
All a guy has to do is pull your light switch knob all the way out-like turning on the headlights- then depress the small button on the switch itself.....this will let you remove the knob and rod by pulling out. now you can unscrew the bezel holding the switch to the dash.
HEY NOW!
donkey69 is offline   Reply With Quote
Old 02-13-2005, 09:41 AM   #7
vtblazer
vtblazer's Avatar
That's the key.
The knob must be pulled out FIRST, then reach on top of the switch and feel for the button, push down and pull out the knob completely.
vtblazer is offline   Reply With Quote
Old 02-14-2005, 03:08 PM   #8
Tynee
I miss this truck.
Tynee's Avatar
Helps if you can bend your arm half way between the wrist and elbow. Also a forth knuckle on each finger helps.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 02-13-2005, 08:58 AM   #9
Huck
Huck's Avatar
However, if the "designed method" of pushing down the button to release the rod doesn't work, (and it rarely does for me) just turn the knob hard counterclockwise till it twists off. ON install, use a tiny bit of gorilla glue in the knob hole. (:>)
Huck is offline   Reply With Quote
