Old 02-14-2005, 03:05 PM   #1
Zonaman
Zonaman's Avatar
The Sky Is Falling!
OPPS! Wait a sec, they call that stuff "rain"! Not too much of that in Arizona. But we've been catching up lately. I noticed a leak in my cab on the driver's side down the kick panel. Any ideas on where to look for the culprit?
Thanks in advance!
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 02-14-2005, 04:58 PM   #2
demi
demi's Avatar
I hear ya about the rainy thing. When it rains in the desert it's always
Here's a pic from my backyard when the sun was going down.
As for your leak, try looking around the corner windshield rubber. That sometimes is the culprit.
demi
demi is offline   Reply With Quote
Old 02-14-2005, 05:00 PM   #3
mr402
I found my leaks at the top of the windshield. Had to pull the window to figure out where. Minor rust clean up and it was good to go.
mr402 is offline   Reply With Quote
Old 02-14-2005, 05:42 PM   #4
67chevemall
67chevemall's Avatar
Backyard!! holy fn mother of God u lucky soul that looks like heaven!
I'd show you my backyard but would ruin the thread!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-14-2005, 06:06 PM   #5
hotrodtroy
hotrodtroy's Avatar
You might want to look under the cowl at the bottom corners of the glass. There is a seam on either side. Mine leaks on the drivers side, I'm thinkin' duct tape 'ill fix it.
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
Old 02-15-2005, 08:50 PM   #6
Zonaman
Zonaman's Avatar
Couldn't resist- here's one more
I'll be looking for leaks where yous guys suggested. Thanks again!
Old 02-16-2005, 04:51 AM   #7
RON WOODGEARD
Resident Young Old Dude !
We've got about 5" of new snow today....
I was just getting ready to pull the truck out and make room to work on it again...
Friggin Snow!!!!
RON WOODGEARD is offline   Reply With Quote
Old 02-16-2005, 06:59 AM   #8
modifiedGMC
You might also want to check around your drip rail at the top of the cab. Mine had a couple of small holes rusted and the rain would run down through to the inside and run down the kick panels. I discovered this after I painted the interior and noticed a "rusty trail" down the kick panel. I cleaned the drip rail treated the rust and filled the seam with autobody seam sealer. No more leak!
modifiedGMC is offline   Reply With Quote
Old 02-14-2005, 07:32 PM   #9
Gee_Emm
Possibly coming into the cab thru the kick panel vent due to a clogged drain in your cowl. Stick your hand thru the vent and feel around for any garbage that might be in there blocking the drain hole.
Gee_Emm is offline   Reply With Quote
Old 02-14-2005, 10:20 PM   #10
Russell
Professional Grade
Russell's Avatar
Wow, I just found a new desktop...
I just quickly cropped it to take the structure at the bottom out, along with editing the picture to remove the sign and post, it looks just like some sort of prehistoric thinger!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
