02-15-2005, 03:36 AM | #1 |
Fixed column....no dome, dash or tail lights???
So I got my column fixed, and for good measure I changed out my plug wires. Pretty good day.
This morning I go out to get in my truck, and there's no dash or dome lights. I figured it was a busted fuse, and sure enough, so I replaced it, and POP, the fuse blows again. Turns out I don't have tail lights either. I have headlights, and backup lights. Just no taillights, and hitting the brakes shows nothing. So...I did something that's now causing a short somewhere in the engine compartment or under the dash that's blowing the instrument, dome and taillight fuse... Anyone have any ideas, or am I screwed and have to chase it down with a 12v tester?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
02-15-2005, 06:40 AM | #2 |
My guess would be something in the column got pinched, maybe shorting out the wire for turn signals.
02-15-2005, 01:18 PM | #3 | |
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
02-15-2005, 03:04 PM | #4 |
Damn. Actually, that's a good thing, because I don't have to spend a million years tracing all of the wires under my dash. You guys are probably right. The turn signal harness off of the turn signal switch is unbelievably tight in the column...looks like I'll have to take it apart and see where the problem is.
02-15-2005, 04:42 PM | #5 |
It's a catastrophic success.
dash,park and tail lights are on a different circuit than stop and signal.But the problem may be the same, a pinched wire. Does yours column have a light or fiber optics? Did you have your dash apart? check dash lighting wires.
02-15-2005, 09:09 PM | #6 |
Cause the Chicks DIG IT!!
Just like sneaky said, did you have your dash apart more than likely for a column fix? That plug into the back of the dash gauges has flimsy little connectors in it and they can get moved, or distorted. That could be a possible cause.
02-15-2005, 11:03 PM | #7 |
I didn't touch my dash, but the plate that goes under the column where it runs past the dash I had to take off to run the harness and the fiber optic through when I took the column apart.
02-15-2005, 11:04 PM | #8 |
Oh, and there are NO tail lights. It's not just the brake lights I'm missing. I have no tail lights period.
02-15-2005, 11:11 PM | #9 |
Designated Grumpy Old Man
Unplug the column harness then put another fuse in. If it doesn't blow out then your problem is in column. If it does blow then look else where. Also if the problem is in the column unplug each wire from the connector and then reinsert them one at a time until the fuse blows then you know which wire is your problem. Good luck.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
