Old 02-15-2005, 10:49 PM   #1
EyeH8the24
EyeH8the24's Avatar
rack question.........
what rack is recommended for a 67-72 truck.? i want to change to a rack since i have cut my cross member..any help ?? i was thinkin of a 93 camaro rack ....it looks like it will work great!
EyeH8the24 is offline   Reply With Quote
Old 02-16-2005, 03:04 AM   #2
fastbagged68
fastbagged68's Avatar
Power is from I beleive T-bird like 79-89. I think.
fastbagged68 is offline   Reply With Quote
Old 02-16-2005, 04:04 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
83-87 for the power T-bird Rack.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-16-2005, 09:46 PM   #4
GMCGRANDS
NAPA 22-248 Power rack for Mercury Cougar 82-83. Ford design.
Mark
72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction
05' GMC Sierra Denali LQ9
GMCGRANDS is offline   Reply With Quote
Old 02-17-2005, 07:26 PM   #5
el curioso
el curioso's Avatar
i have a 1995 t bird from which i can get just about any part off. will the rack from this one fit a 1972 c-10 front factory disk brakes.
el curioso is offline   Reply With Quote
Old 02-18-2005, 05:34 PM   #6
GMCGRANDS
This is not a simple bolt on propostion. You must weld mounting points with the correct spacing to the crossmember. Then you will need someone to machine adapters to adapt the rack end to the truck tie rod ends. The ford racks threaded rods are smaller than the truck tie rod end and both are male. Most racks I have seen will have to have the threaded ends shortened as well. Then its very difficult to get the correct geometry to eliminate bump steer. Bill Turner sold crossmembers with this Mod but there were alot of issues (wouldnt recommend) and still required some fabrication skills. I have one and I was never satisfied. Several other board members have as well. To my knowledge none of us have made everything work but keep in mind we were all trying to accomplish multiple things at the same time ie Tubular control arms, Crossmember drops, and rack and pinion. I have no doubt it can be made to work with enough time and money, but I got tired of throwing both at it and went to a Fatman fabrications IFS. If you are serious and wont to spend the time, I have a crossmember with the rack mounts already in place, Tubular upper and lower arms, rack, etc. that can be bought cheap. Pm me for details.
Mark
