05-30-2002, 08:28 AM | #1 |
4x4 lift kit,which is best
have a tuff country 4 spring lift know and it rides harsh,are there any soft ride kits that are soft". looking to buy 4 new springs.
1972 3/4 4x4,14bolt locker rear, dana44 lock right front, sm465, sb 400, blazer tank,dual batterys,3"lift,32-9.00-16 super swampers daily driver other trucks 1972 1 ton dually 4x4,454 4 spd,,235-85-16, flat bed front and rear winches, rear gas tank and under bed gun safe.tilt wheel |
05-30-2002, 09:05 AM | #2 |
Broke
Hey 8mag, I'm using Skyjacker Softrides right now, and the ride is actually very good. I live down 3 1/2 miles of very rough gravel road, so it gets tested very well! One thing I did give up is load support in the bed? But I do plan on installing air bags in the rear, that way I have the best of both worlds!?!?
I noticed the spec's on your 1972, 3/4 4x4, 14bolt locker rear, dana60 and locker front, nv4500, 383, blazer tank, dual batterys, 4" lift, 285-75-16's. That’s pretty much exactly what I would like to do to mine! You don't by chance have any pics?
72CheyenneSuper1ton4x4BigBlock Last edited by Bram; 05-30-2002 at 11:44 AM. |
05-30-2002, 09:09 AM | #3 |
To some degree, a 3/4 ton is just going to be rough. I would start by getting some adjustable shocks and playing with those as well as dropping your tire pressure. I'm sure max load is at least 50 psi if not 65 on your tires. Try running them around 35 when you aren't carrying a load, maybe less. The bigger the tire, the less psi it needs. Another option for the rear would be a Velvet Ride Shackle combined with your existing springs.
05-30-2002, 11:36 AM | #4 |
Broke
8mag, what type of lockers are you using in the front and rear?
05-30-2002, 11:59 AM | #5 |
Livin' it up.
I'd definately suggest greasable shackles all the way around, they not only can provide some lift and great suspension flex but helped rides in my 4x4ing vehicles a ton.
just my .02
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
05-30-2002, 12:07 PM | #6 |
what shocks u running?
I am running rancho 9000's and they ride great. 20-25 lbs of air in 35/1550 super swampers. i also have heavy duty tuff country springs.
05-31-2002, 08:25 AM | #7 | |
05-31-2002, 10:34 AM | #8 |
Broke
Hey 8mag, did your truck have an automatic trans originally? If so how hard was the conversion to the NV4500?
72CheyenneSuper1ton4x4BigBlock |
06-03-2002, 04:32 PM | #9 |
Broke
ttt
06-03-2002, 10:15 PM | #10 |
Strongman Garage
how do the dual detriots handle on the street?
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
06-04-2002, 01:24 AM | #11 |
Collector of rusty Items
Look into that new Eaton Electric locker. Detriots suck on the pavment.
http://www.traction.eaton.com/prod1.htm http://www.rockcrawler.com/techreports/eaton_elocker_preview/index.asp
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
06-04-2002, 04:51 PM | #12 | |
06-04-2002, 04:53 PM | #13 | |
