Old 02-19-2005, 01:06 AM   #1
Dick Dale
Excelsior, You Fathead.
Dick Dale's Avatar
Turn Signal Lever Replacement
I am going to pull out my steering column to paint and repair it. Does anyone have the instuctions on assembly and repair so I can fix everything? Also, what is a cheap steering wheel that I can put in without havig to adapt parts.
Go Navy. The Sea Is Ours.
Budget 350 Build
http://67-72chevytrucks.com/vboard/s...38#post2264638
Dick Dale is offline   Reply With Quote
Old 02-19-2005, 01:17 AM   #2
Bob Moore
Steering Wheel
Almost every GM wheel up to Airbag (92?) will fit the spline and most horn contacts will work. Pick one you like the looks of and chances are it will work.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 02-19-2005, 07:57 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And as far as the turn signal lever, once the wheel is off, you'll see a tiny phillips head screw holding the lever on.
