02-21-2005, 01:12 AM | #1 |
Disc Brake Conversion
I finally got around to putting my disk brakes on my 14 bolt FF. I was going to put it in the 83 but now I have decided to put it in the 91 burb I just got. This little project was alot less trouble than I thought it was going to be. I got the plans for the brackets off of e-bay but I modified them a little so they would be stronger and safer in my eyes. I made them at work and they were laser cut on our new Mazak laser.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
02-21-2005, 01:13 AM | #2 |
More pics
02-21-2005, 04:54 AM | #3 |
user # 2756
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
02-21-2005, 11:45 AM | #4 |
Does the rears have ebrakes?
02-22-2005, 12:16 AM | #5 | |
02-22-2005, 12:21 AM | #6 |
man, you really ought to help out some of us and post some part numbers?
i'd love to do this mod someday did you have to use another master cyclinder? -bigarmzz- |
02-22-2005, 12:29 AM | #7 | |
2 @ 716779 5523 567 Brake Rotor $23.99 each 1 @ 095745 C503 Disk Brake Caliper $15.99 1 @ 095752 C502 Disk Brake Caliper $15.99 The number came from my receipt and they told me that that particular rotor is not going to be a stock item and when the supply is gone they will be gone. I am sure they will replace them with another brand.
02-22-2005, 12:51 AM | #8 |
cool, this needs to be a sticky
do you have a link where you bought the plans off ebay? i'd need them for a half ton though....12 bolt rear do they give you the plans for the spacers as well?....how exactly did you modify your spacers?.. i'd have to take the plans to a local machine shop.. -bigarmzz- Last edited by bigarmzz; 02-22-2005 at 12:55 AM. |
02-21-2005, 05:56 PM | #9 |
what were the calipers sourced off of?
02-22-2005, 12:19 AM | #10 | |
02-21-2005, 08:40 PM | #11 |
I've been wanting to do this conversion for years now! Looks good. How thick is the spacer between the caliper bracket and axle flange? If ya don't mind me askin'.
What are ya gonna use for a master cylinder/ prop valve?
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
02-22-2005, 12:22 AM | #12 | |
02-22-2005, 12:09 AM | #13 |
Very nice pics
Support The Board |
02-22-2005, 05:12 AM | #14 |
My brakes where done with the original backing plate , rotors and calipers from the front. A notch has to be cut in the backing plate and holes drilled. There is also a spacer. I have the size for the spacer or I can get them. I have always had this info but noone has ever contacted me for it.
02-22-2005, 09:51 AM | #15 | |
I was the guy at your back axle taking measurements, you know in the parking lot at that store we all shop at.... Ok maybe not... Nice article.
Support The Board |
02-22-2005, 12:01 PM | #16 | |
I know the holes have to be drilled in the backing plate but this is the first I've heard of a notch. What's the notch for? Also if ya could, the thickness of the spacer would be appreciated.
02-22-2005, 11:39 AM | #17 |
The guys that came up with this conversion got all the info from a article in one of the 4x4 mags. They used a magnifing glass to get the part numbers off the parts in the article. I thought that was pretty funny. The only thing this one lacks is the ebrake and it can be had but very expensive from what I have found. Myself I never use a ebrake with a auto, but someone using a standard would have to have something.
Oh, and I'm not trying to steal bussiness or the thread. The 14 bolt ff is pretty easy. |
02-22-2005, 01:53 PM | #18 |
Not to steal the thread.. But 454 72 4x4 I think I have a set of aluminum spacers from an older kit, before I went to work for blackbirds..
I was only going to ask 60. plus shipping. If your interested, i can take a look for them.. I know mudder has seen them in previous for sale threads I have made.. There are alot of great websites for the 14 bolt conversion.. pirates4x4.com ck5.com and others... I would however ask you guys to do what soleeagle did.. Use a thick spacer instead of the pipe spacers.. I have seen first hand the pipe spacers break and twist under a set of 39 boggers hard braking.. I would offer our kits to you guys, but we don't just sell the brackets.. shakerbuilt.com and some guys on ebay sell them.. Pretty good prices too. If you use shakerbuilt. please tell him blackbirds sent ya..
Support The Board Last edited by drink2mny; 02-22-2005 at 01:55 PM. |
02-22-2005, 02:17 PM | #19 | |
Good idea about the pipe spacers too. (Not using them that is!) Dumb question; why doesn't blackbird sell just the brackets? Is there that much markup on the calipers? I'd think he'd sell alot more quantity if he'd sell just the parts people need. (IMHO) soleeagle; which lugbolts did you use? Fronts or rears?
02-22-2005, 04:26 PM | #20 | |
Easiest to answer that one is we just chose not to sell them seperately.. We found out that there were different rotors (different thicknesses) for sale.Which we found out brought on stress on the bracket. So instead of making 2 different brackets we went one type of rotor that matched what we had. We could see a potential for someone to try and sue us if their bracket broke if they installed it wrong. this way with everything we sell together we know it works.. So it became a liability issue for us.. Plus there are alot of folks that don't have or can't find a machinest or want to deal with a parts store to build a kit.
Support The Board Last edited by drink2mny; 02-22-2005 at 04:29 PM. |
02-23-2005, 12:37 AM | #21 | |
02-23-2005, 03:14 AM | #22 |
a ton of places sell the brackets for those of you that don't have access to equipment to machine them. price is usually from 50-75 for a set and then you just need the 3/4 ton front rotors and calipers and break lines
http://www.diy4x.com/brakes.htm http://www.shakerbuilt.com/14_Bolt.html http://www.offroaddesign.com/catalog/catalog.htm http://www.bluetorchfab.com/oscomm/c...80cc2dd2df24b2 http://www.greatlakeoffroad.com/ http://www.sky-manufacturing.com/
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
