Old 02-21-2005, 07:36 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Recommendations on a 700r4 rebuild kit
As I posted this weekend I got a mechanic here in town who is going to give me a free 700r4. I would like to know what's a good rebuild kit to use. He told me he thinks it's from an early 80's car, but not for sure. I know that the later ones are better to have, but free is free. What kit can I get to make it better. Nothing special. I think it's a mechanical speedometer. He saw it and it has a hole on the driver's side of it. He said that some kind of switch goes there but he doesn't know what it is. Torque Converter comes with it. I have a TH400 as of right now.
thanks for the advice,
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-21-2005, 10:07 PM   #2
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Sell that one and buy one from these guys...Cost you more to rebuild it with GOOD parts than just buying from 700r4.com. Not to mention the early 80s 700s wheren't much and have alot of weak lengths in them.
Check them out.
http://700r4.com/sitemap.shtml
lata
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 02-21-2005, 11:13 PM   #3
racer face
s&l68 is right , I think 83 was the first year and the worst.
to make a 700r4 work right most trans guys use the case and replace the guts with
4L60E parts. The trans I need for a 502/502, prices have be 1500-2000$,but I think
I'm going to talk to these guys there price was less than 1300$
Thanks for the sit info s&l 68
Pat
______________________
1968 1 Ton Dually Flatbed 327/th400
1968 C30 Open Road 327/th400
1997 F350 CREWCAB 4X4 460 BIGBLOCK
racer face is offline   Reply With Quote
Old 02-21-2005, 11:22 PM   #4
SweetandLong68
Your UncleBen
Not a problem...I have used 700s from bowtieoverdrives.com/700r4.com and there are very good quality. Espeically if you opt for the ugraded sunshell and drum...These are probably the Weakest part of a 700r...I mean all of them...I would replace this piece in any rebuild of a highperformance nature...Believe me...You dont want to see what they look like when they come apart
Check this out...From 700r4.com...
Behind engines above 450 hp and 450 ft/lbs of torque output, the input shaft to drum connection point becomes prone to fracture and the spline sun gear section will start ripping off the sun shell. Our level Three Transmissions have the following parts added for increased strength and reliability above 450 hp and 450 ft/lbs of torque. Reinforced input drum & sun shell for optimum strength with 30% larger fourth gear servo piston. These components are specifically engineered to help prevent breakage in applications with exceptionally stout motors. Experience has proven this engineering to be correct!
lata
CHRIS
Here is a pic of that pesky part...
Old 02-21-2005, 11:22 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is some info on id ing the 700 r4
http://www.highperformancecars.com/crosley/700id.htm
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 02-21-2005, 11:32 PM   #6
5150
C10 Club Tennessee
5150's Avatar
Guys I don't have a high performance engine, it's just stock. All I want is something with overdrive and that gets better gas mileage. Nothing fancy. I thought someone had said one time that even though it was an older 700R4 I could upgrade the insides with certain kits.
Bryan
www.gmtruckshow.com
Old 02-22-2005, 01:48 AM   #7
SweetandLong68
Your UncleBen
Even then....The early 700r4s are not a good 'upgrade' IMO. I feel what you are saying about having overdrive and whatnot but the early 700s are weakkkkkkk....I wouldn't have one...That is probably the reason that the guy gave it to you.
lata
CHRIS
Old 02-21-2005, 11:35 PM   #8
5150
C10 Club Tennessee
5150's Avatar
One thing I said I had a TH400 in the opening thread, sorry I only have 3 gears, so I guess that means I have a TH350----DUMBA$$
Bryan
www.gmtruckshow.com
Old 02-22-2005, 01:47 AM   #9
SweetandLong68
Your UncleBen
You could have either a TH350 or a TH400. Both are 3 speed transmissions. TH400s are usually found behind big blocks and whatnot so I thought you might have a motor with a bit of HP
lata
CHRIS
Old 02-22-2005, 09:50 AM   #10
5150
C10 Club Tennessee
5150's Avatar
I'm going to go pick it up tomorrow I'll find out the year of if by looking at the stamp. My friend, the mechanic, doesn't know too much about tranny's he's just trying to clean out his place. He does have one out of a late 80's caprice he told me months ago he'd sell me for $25. The thing is that I talk to him the other day and he mentioned this one and I figured free is better.
Bryan
www.gmtruckshow.com
Old 02-22-2005, 01:55 PM   #11
1969K10
1969K10's Avatar
I just helped a friend up here rebuild his 700R4, and he got his kit thru JCWhitney. It was NOT a high performance upgrade, just a stright rebuild. i think he paid $80. I thought the kit was ok, seals, clutch packs, new SS balls, springs, etc. The only thing the kit was missing that he purchased in addition, was the 2-4 band. He got a kevlar from a local tranny shop for $20 if I recall correctly.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 02-22-2005, 08:49 PM   #12
SweetandLong68
Your UncleBen
That $25 would be well spent IMO...
lata
CHRIS
