02-25-2005, 03:04 PM | #1 |
Electric choke hook up ??
Where does the wire for the electic choke go? I thought i had it but i when i plugged it in, my temp gauge read all the way to hot...so i think i found out why my temp gauge doesn't work...but wheres the wire for my electric choke? i have an Edelbrock 1406 on a 305 in a 78.
02-25-2005, 04:12 PM | #2 |
Professional Beer Tester
Chevyguy, none of the 78's I've seen came with electric choke, only the manifold heat choke. You might not have a wire for it. All you need is a wire hooked into the fuse block on one of the terminals that are hot only when the key is on. Hope that helps.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
02-25-2005, 05:12 PM | #3 |
95 extended cab sportside
Find a hot spot then a ground thats what i did i dont a have close pic or i would help but i have this one. There a red going in the back.
then i drilled a hole in the alt. cover for a good ground. You cant see the black or the red but you can see in the right side there is a wire that is behind the 2 hoses its connect right there sorry if that dont help, and if it does thats good.
95 Chevy k 1500 00 Chevy Silverado 1500 07 cobalt Old ladies car] |
02-25-2005, 08:12 PM | #4 |
oh so all it needs is 12 volts huh? sweet...didn't know if that was the case or not, thanks guys!
