05-31-2002, 10:55 PM | #1 |
creator of kong
which power steering pump to use?
When changing from a long water pump, back to a short one, with a small block chevy, does the power steering pump change also? Where does it mount, if it is different? Thanks
05-31-2002, 11:25 PM | #2 |
the pulley is different,and possibly shaft,be simplier to just use original style-
06-01-2002, 11:37 PM | #3 |
Also, GM switched from a woodruff key and nut pulley retention 74 and earlier to a 75 and later press fit pulley. At the same time, pulley alignment changed. (I have a 75 Corvette crank add-on pulley and PS pump pulley on my AGR pump. Summit sent wrong pump) All of the pulley alignments were different, so I could not use both of the 'vette crank pulleys, just the front one. You'd have to change water pump pulley and possible AC brackets. PITA.
06-02-2002, 03:00 AM | #4 |
No, U Da Man!
I used a ps pump off a 73 p/u.Just mounted it on my 72 brackets. Works great so far
(sold ole blue 1972) 1997 Dodge 1500 5.9L 1996 Saturn SL2 1.9L 2002 Mitsubishi Montero 3.0L 2005 Ford Escape 3.0L 1967 Olds Vista Cruiser 330-320HP |
