Old 02-26-2005, 03:12 PM   #1
superchevy
Got big-block?
superchevy's Avatar
will '73-'87 454 brackets/pulleys work on a 67-72 big block truck?
Wondering if the '73-'87 454 long waterpump pulleys and brackets will work on a 67-72 truck if you put on a long w-pump instead of the stock short pump?
Will the powersteering pump/bracket clear the frame rail? Would you run into a problem with the fan too close to radiator?
Anybody done this?
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 02-26-2005, 04:11 PM   #2
Bob Moore
Answers to your questions.
Yes.
Yes.
Yes.
Yes.
Sincerely yours,
Bob
I used a LWP set-up in my 67. Didn't know about the SWP when I did it in 1993. Power steering clears no problem. I don't recall if I used 68-72 pressure hose or 73. Either may work but I would try the 73. I used a fan clutch and the fan is VERY close to the radiator and is WELL inside the shroud but has not overheated in 12 years. I have had this truck on the road for 12 years since March 93 without trouble (50,000 miles).
My next project is a 67 2wd 502/4L80E and will have AC so I am going SWP on it.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
