![]() Join Date: Jun 2003
On a 71/72 K20, are AUTOMATIC and MANUAL transmission crossmembers the same part. Can they be interchanged with just different mounts??
Thanks for your knowledge, 72longbed |
What different mounts? The mounts go to the adapter between whichever tranny it came with. AFAIK, oem '71/'72 adapters all used the two piece mounts. My '71 K10 w/SM465 and my '71 K20 w/TH350 use the same transmission xmember mounts. Both have NP205s, of course. BTW, Energy Suspension makes the two piece mounts in poly.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
4x4poet,
what is a AFAIK?? So the transmission mount is eliminated, and the crossmember bolts only to the transfer case adapter?? Let me know if this is correct. Thanks, 72longbed |
thats right.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#5 | |
I was going to ask about those poly mounts and thought I would jump in here. Any pro's or cons with these? Do I have to use there motor mounts to? |
#6 | |
Cons: Cost. About $60 for the trans mount pair. About $20 for the torque bushings. Pros: Impervious to oil, grease. Won't rot as rubber does. Retains shape. Made of soft poly to allow some flex and not transmit vibration. Comes with gold, cad-plated plates. Looks great if you crawl under the truck. ![]()
![]() Join Date: Dec 1999
I saw the poly engine mounts available at Brothers. They are listed as big block mounts. They are the same as the 4x4. I used the same crossmember on my last 72 that I converted from manual to auto. Had a donor truck.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
user # 2756
![]() Join Date: Jun 2001
As Far As I Know=AFAIK
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
