Old 04-09-2002, 09:18 PM   #1
Brian19692
Post Burnt wire
I checked out the damage from the little wire fire today. The wire that runs from the battery to the fuse box was burned. Which ruined the headlight harness. It also burned from the fuse box to the ignition switch, pretty much taking out the under dash harness. Anyone had good luck with aftermarket harnesses?
69 short box 4x4
72 long box
69 Camaro 327 4-speed
71 4x4 suburban, soon to be crew cab short box
87 S-10 V-8 FOR SALE
Des Moines, Iowa
67 short 2wd. FOR SALE
69 long box w/72 grill
Des Moines, Iowa
Brian19692 is offline   Reply With Quote
Old 04-10-2002, 04:57 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
Post
how did this happen ?!
Fast68Chevy is offline   Reply With Quote
Old 04-10-2002, 06:47 AM   #3
Brian19692
Post
I have no idea how it happened. About an hour after I got home I noticed the headlights turned on. went out there and the cab was full of smoke.
69 short box 4x4
72 long box
Des Moines, Iowa
Des Moines, Iowa
Old 04-10-2002, 07:16 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Post
I'd bet some wires got pinched somewhere. Did you do any work just prior to this?
I once pinched some wires when I installed my rear bumper. Went for a drive and about 5 miles away from home, smoke started pouring out of the steering column!
The cheapest way to go would be to grab a harness out of a junkyard truck.
63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle
Parts for sale:
http://www.angelfire.com/trek/mr409/items4sale.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-10-2002, 08:56 AM   #5
BubbaGreen
Post
M&H wiring makes replacement wiring too, they
sell it in pieces, so you can get the sections
that have been damaged. I am pretty sure
GMCPauls sells those.
If you want to replace the entire thing,
Painless makes a kit for our truck, 18-circuit. Sells at summit for approx 300.00
(I think) and it retains the factory style
bulkhead...
What ever you do, keep the old harness, until you get the new one in.
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
