02-28-2005, 09:41 PM | #1 |
In Progress
sway bar
picked up a sway bar from the wreckers today, but i couldn't ge tthe frame brackets off cause the rivits. how have you got them off?
i got the sway bar off a 3/4 ton but ended up only being the 1 1/16 bar, i was hoping for the 1 1/4 but im still happy. i got the bar, new bushings, brackets, and new hardware for $80 canadian
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
02-28-2005, 10:27 PM | #2 |
I recently added a sway bar to my 78 and love the results. The brackets on those are rivoted on. I know of 5 ways to get them off 1. torch easiest 2. drill 3. grinder 4 . chisel hardest. 5. sawsall. I like the grinder or torch method the best. I went down to the chevy dealer and bought new ones 16 dollars each .
03-01-2005, 12:09 AM | #3 |
Insert Witty Text Here
I bought mine at the dealer too. It wasn't worth spending an afternoon on my back laying in oil soaked dirt to save $20.
Slonaker |
03-01-2005, 12:45 AM | #4 |
In Progress
i phoned gm today and they wanted $32 canadian each, not worth it for me
when torching them do u just heat them up and knock em out?
03-01-2005, 06:41 PM | #5 | |
On mine I used an air hammer (chisel), with a chisel tip to remove the head of the rivet and then used a punch tip on the air hammer to drive the rivet through. Worked pretty good. Of course, if you are doing this at the bone-yard, you may not be able to hook up a compressor. Just a thought. |
03-01-2005, 10:13 PM | #6 |
In Progress
ya i guess i should have looked around at the other trucks to see if any were bolted in. thanks for the info!
03-02-2005, 12:37 AM | #7 |
Happy to be here
If your truck is lowered consider either the low profile ones the ECE sells, or don't run them at all....
03-01-2005, 05:42 PM | #8 |
I just took one off a 78 and it was bolted on 4 bolts a side?
It's 4 sale $60.00w/brackets
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
03-01-2005, 06:12 PM | #9 |
Look at all the trucks in the junkyard before you start removing rivets. Some might have been added with bolts, like mine, or might have been replaced with a bolt-in after an accident.
If you get lucky, you can melt the heads off and hammer the rest through with a punch. If not, they will be like the rivets on my upper ball joints that each took about 20 minutes of hammering to push them through after the heads were ground off. Slonaker |
03-04-2005, 12:28 PM | #10 |
In Progress
03-06-2005, 10:50 PM | #11 |
OutOfMyMind & I'llNeverKnowWhy
Looks good. Did you paint the bar too?
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
03-07-2005, 01:30 AM | #12 |
In Progress
ya just some plain black paint, stands out from the rest of the dirt under there.
03-07-2005, 02:47 AM | #13 |
Gettin It One Pice At A Time
I am hopefuly in the market for a sway bar. what years will work on my truck and what size? 3/4, 1 ton? how much should I expect for a junk yard special? $50 to much?
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
03-07-2005, 12:56 PM | #14 |
In Progress
i think any year from early 70's to late 80's should work. i got the sway bar off a late 80's 3/4 silverado, and the frame brackets off a 70-72 1/2. i only paid $40 canadian for my bar so 50 is a bit much
03-07-2005, 04:42 PM | #15 |
so a bar from a 1 ton would fit on a 1/2 ton? cause that would probly be the best.
03-07-2005, 06:08 PM | #16 | |
Slonaker |
