Old 03-01-2005, 02:52 PM   #1
TugOwar
Building pressure in gas tank??
77 Chevy 1/2 ton 350/th350. All stock save exhaust from manifolds back.
This morning I'm driving to work and it starts cutting out at higher rpm. Got worse and worse until I finally had to stop and the engine died. I found the 3/8 rubber gas hose from the fuel line to the fuel pump was dry rotted and spraying gas.
So I think it must be sucking air and thats why its cutting out. But why is it spraying gas out when the motor is off... I loosened the gas cap and a big rush or air/fumes comes out. Strange but oh well..
Called the wife to come get me, gathered tools etc and replaced the hose. Fired it back up and start for home, it runs good until it heats up and then starts the same cutting out again, like its either loosing fire or starving for gas. I pulled over and loosened the gas cap and again it has pressure built up, I left the cap loose to see if that was the problem but it still cutting out if I try to give it much gas, idles fine though.
I limped it on home, closed the gas cap and let it idle for about 5 minutes and then checked and it has built up pressure in the tank again, wtf??
I don't know if the cutting out and gas tank pressure are related or which is the problem and which is a symptom...
I'm going to replace the fuel filter in the carb and spray the carb with some cleaner and see what happens. In the meantime I would appreciate any ideas you guys might have. This has me stumped.
BTW, I can't find any other gas leaks or shorted wires and the fuel pump is only a couple months old.
TugOwar is offline   Reply With Quote
Old 03-01-2005, 04:51 PM   #2
Jonboy
Slots go on anything!
it's possible the vent line may be clogged. That's where I would start.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-01-2005, 06:27 PM   #3
1FaastC10
1FaastC10's Avatar
change your gas cap. they're vented specifically for this purpose. either you've got a non-vented cap, or your vent is bad.
1FaastC10 is offline   Reply With Quote
Old 03-01-2005, 08:17 PM   #4
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Correct me if I'm wrong, but that truck should have come with a evap canister which would prevent pressure build up. I agree with 1FastC10 about the vented cap, but unless the evap can has been removed and the corresponding hose plugged, this should not happen. Does your fuel pump have a return line? May also want to check the pump volume/pressure to make sure it is not bad (even though it is new)
NeCrOmAnCeR is offline   Reply With Quote
