03-02-2005, 11:30 PM | #1 |
14.1 @ 96MPH
GenIII (LS1, Vortec, whatever!) Help: Power Steering Pressure?
I was THIS close to driving my truck for the first time since July tonight. While backing it out of the bay, there was no power steering; we added fluid, went another two feet and noticed a puddle of foamy power steering fluid. It appears to have blown out the seal where the shaft goes into the gearbox.
So, does anything special need to be done to the power steering pump and/or the gearbox? Is there a restrictor we can put in to lower the pressure of the pump? Or is there a gearbox that will take the higher pressure?
Project1970 - LS1 Swap Complete! |
03-03-2005, 12:03 AM | #2 |
Are you sure it didn't just burp out the (foamy) fluid because of air in the system? I had this problem not long ago. I finally had to fill it while the engine was running, and work the air out of the lines before I turned it off.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
03-03-2005, 12:04 AM | #3 |
If you need a seal Autozone has them--Powercraft # 7095-easy to install.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
03-03-2005, 12:16 AM | #4 |
14.1 @ 96MPH
We added the fluid while it was running.
On the other hand, I also have a sneaky suspicion we may have mounted up the lines backwards; it wouldn't be the first set of lines we did that to. Is this diagram I just made using someone else's photo correct? And if we DID hook them up backwards, does that mean it's probably just that seal?
03-03-2005, 01:11 AM | #5 |
That looks correct to me. The top (referencing the hoses, not the connections) line is definitely the pressure line (crimped hose) and the bottom line is the return line (can just barely see the hose clamp on the hose).
1972 Blazer body...need to get a thread started for the rest of the story |
03-03-2005, 01:34 AM | #6 |
14.1 @ 96MPH
That's what I thought...if it is backwards, that'll at least make me a bit happier that the repair is cheaper.
