03-05-2005, 11:16 PM | #1 |
Spring question
I just brought home a '72 for parts. It has the all the parts that I need to swap my 69 to 5 lug and power disc brakes. I noticed that this truck is slightly lower than mine and I was wondering how to identify stock springs from drop springs. If it does turn out that these are drop springs I would like to trade them for stocks if anyone is interested.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug |
03-05-2005, 11:20 PM | #2 |
Still drivin' a Rat Rod
There is a similar thread going on right here.
http://67-72chevytrucks.com/vboard/s....php3?t=139272 HTH
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
03-05-2005, 11:27 PM | #3 |
I guess I should have stated that I have coil springs. Thanks for the quick reply Brainchild.
03-06-2005, 12:10 PM | #4 |
ttt
03-06-2005, 01:30 PM | #5 |
its all about the +6 inches
Use the original springs on the 69...sell the 72's springs as one inch lowering springs.
They do settle down over the years, my old GMC had 500 K, and everyone swore the front end had been dropped, but all that had been done up front was the original sagging springs were left in place. |
03-06-2005, 03:33 PM | #6 |
If they are dropped springs, they are most likely really clean and black like they were painted recently. I have a pair of stock ones that I'll ship to your front door for $50 if you're interested.
03-06-2005, 11:48 PM | #7 |
Thanks for the responses guys. I am just being lazy I guess. I can do the back ones easily but the fronts I have to pull apart on both crossmembers. Is there a safe way to pull them apart with a spring compressor?
03-07-2005, 12:23 AM | #8 |
you don't need a spring compressor. They are more for struts than A arm suspentions. Just place a floor jack under the lower a arm, seperate the ball joint, and lower the jack. the spring will just fall out. If you don't feel safe, then run a cahin through it and around the frame or something.
