Old 06-02-2002, 08:58 PM   #1
chevyman 68 C/10
chevyman 68 C/10's Avatar
need rear axle mounts
I have a 96 trans-am posi rear end with a 380 gear and disc brakes. I need to find a place that sells weld on brackets to mount to our rear ends. I have found a machine shop that will add the 5 on 5 patern to match front discs. PLEASE HELP!!!
69 Chevy short fleet side soon to have LT1 and 4L60E pb. ps cruise and air.
68 Chevy short fleet side 400 sb 5 inch chop top pb. ps. pw. 350 auto and shaved handles
68 anniversary no engine long wheel base 400 auto FOR SALE
68 Chevy fleet side long wheel base complete parts truck.
chevyman 68 C/10 is offline   Reply With Quote
Old 06-02-2002, 09:00 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
american classics or chevduty sells a panhard bar kit, you can get axle pads from jegs
68SWB4x4 is offline   Reply With Quote
Old 06-02-2002, 09:34 PM   #3
Mike C
Mike C's Avatar
You can buy pads from Summit for $15, Mopar section of catalog. IMO, you are wasting your time/money. The Camaro rear is what I call ultra light duty, it has insufficient ability to shed heat in the brakes for the weight of the truck, the housing is narrow so you will have to run wheels with lots of positive offset, the differential is not suitable for the power/weight of truck, the axle tubes are not thick enough for the trucks weight, and I could probably think of some more...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-02-2002, 10:45 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
i agree totally, you are wasting youer time trying to put such a tiny rear end under your truck, it wil never hold up and the type of limited slip they have wont last long either. you owuld be better off snagging a lincoln or caddy disc rear or use the parts to convert to discs on your current axle
early classic has the kit also
good luck
Fast68Chevy is offline   Reply With Quote
