Old 03-07-2005, 11:58 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
cutting front coils to drop
I just want to get a two inch drop up front on my 68, I have some coils I pulled from my parts truck....or whatever is left. I know you can cut off one of the loops. BUT how many would I have to cut to acheive a two inch drop....or as close too. Also when replacing the shocks with shorter ones do I need to buy special "drop shocks" or how would I go about getting some that are shorter???
Thanks guys...
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 03-07-2005, 04:44 PM   #2
Frank_Zeller
Frank_Zeller's Avatar
1 coil is 2 to 2.5 inches. Stand the springs side by side then cut the second one at the same height. Maybe a little more or less than one coil on the second spring. If you dont do this the front will lean to one side.
I see your not to far from Austin. I have a cut pair you can have if you want to make the trip.
Frank
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 03-10-2005, 06:45 PM   #3
SWINGSAX68
SWINGSAX68's Avatar
thanks frank......I have a set I'm gonna cut myself....a hack saw or grinder should work right????
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 03-10-2005, 11:28 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by SWINGSAX68
.....a hack saw or grinder should work right????
Yeah a cut off wheel works good too. You cab use a torch as well if you submerge the spring in a bucket of water up to the point that you want to cut it. This will keep the temps low enough that you don't loose tempering in the spring...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-11-2005, 08:59 PM   #5
RUDEDAWG
RUDEDAWG's Avatar
I just used a metal cutting chop saw and it went through the spring like butter and it hardly even heated up the spring. I cut exactly 1 coil off and it gave me a 2" drop. Hope this helps.
'72 1/2 ton short box
468 BB forged crank/rods/pistons full roller. Msd 6 AL ignition
turbo 400 tci. 2800 verter
ladderbar/coil rear with currie built ford 9'' rear, 4.11 gears
custom built rear frame
tubbed, 33/19.50/15 rear m/t.
m/t skinnies in front
still under construction
RUDEDAWG is offline   Reply With Quote
Old 03-10-2005, 06:47 PM   #6
SWINGSAX68
SWINGSAX68's Avatar
P.S. I am interested in lowering blocks and ubolts for the rear, of you got any 2-2.5 inches is good.....give me a few weeks and if you want to let them go I can take them of your hands then!!!
Thanks Frank.
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
