Old 03-09-2005, 02:30 AM   #1
500HP/SB
please don't break
500HP/SB's Avatar
H2 wheel offset
i know installing 8 lug 17" H2 hummer wheels has ben discussed and i plan on using some when i do a 1 ton axle swap since they are so cheap. just recently i was told the H2 wheels are a different offset than standard 8 lug GM wheels. Does any body know what this offset is and how much its differnt from normal?
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 03-09-2005, 07:05 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
brewski* put a set on his 71 K20 I believe. PM him.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-09-2005, 07:58 AM   #3
Blazer1970
Blazer1970's Avatar
The offset is the same as all other GM 8 lug wheels. They have 5 5/8" backspacing, but that is because they are wider than most stock wheels (8 1/2" vs. 6 1/2"). The 6 1/2" wide wheels have about 4 1/2" backspacing which works out to the same offset.
Blazer1970 is offline   Reply With Quote
Old 03-10-2005, 08:17 PM   #4
500HP/SB
please don't break
500HP/SB's Avatar
thanks alot, can some one explain to me the differnce between backspacing and offset and where they are measured from?
titanspeed.com
Old 03-15-2005, 02:51 PM   #5
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Backspacing is the distance from the mounting surface to the lip of the wheel.
Offset is the distance from the mounting surface to where the centerline of the wheel would be (8" wheel's centerline would be 4" from the lip).
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
