03-10-2005, 10:24 PM | #1 |
Wirey Problem(with pix)
OK, I'm wiring a custom dash for my 69 C10 P/U.
(See first pix) I'm going to use an electrical oil pressure guage instead of the old copper line/analog guage. Well I installed and electrical oil pressure sender in the oil port. I've installed a new engine wiring harness with the Dark Blue wire connected to the spade lug on the oil pressure sender. So now I'm trying to wire in the guage. The dash connector pinout in the wiring diagram (See second pix) is Fig 53 from the 1969 Chevy Truck Service manual. The actual dash panel wiring connector (See third pix) doesn't match the wiring diagram. The connector has (one one side) a black, 2 grays, dark blue, light blue, light green and a black wire. That doesnt match the wiring diagram. At any rate, I've got everything wired up except the oil pressure sender. The oil pressure sender is connected to a dark blue wire (as per the engine wiring diagram) which goes through the fire wall. The problem is I can't find this darkblue wire in the dash harness. There is a dark blue and light blue wire in the harness and those are the right and left blinkers. Can anybody help on this problem? Jim Mt Juliet |
03-10-2005, 11:13 PM | #2 |
Msgt USAF Ret
Well this may not be much help but my Haynes wiring schematic shows a pink wire common to all the dash gages and then a dark blue wire to the op gage. It is also grounded with a black wire. The plug in your picture shows a pink and a dark blue wire . Are those from the engine or the dash? What are the corresponding wires that they plug into? and before you yell at me remember I'm not there to look at it LOL
Vettevet
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-10-2005, 11:18 PM | #3 |
someday it will be done!
I'll be of zero help to you but I will say that that is a beauty of a guage panel!Aluminum?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
03-10-2005, 11:46 PM | #4 |
http://www.gmcpauls.com/Tech%20Tips1.htm
Above link should help. The picture of the connector is for a gauge dash--your diagram is for a idiot light dash. Just run a wire from sender to gauge (-). Then run a wire from pink wire in connector to (+) side of gauge. (Pink wire is hot only with switch on). On above link scroll dowm to connector diagram.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
