Old 03-12-2005, 08:49 AM   #1
willow72
willow72's Avatar
problem or not?
my brake booster vacume line runs from booster too a tee then another line runs too pvc valve then too the back of my demon is this agood thing too do or not? if it is a problem where should the brake booster line hook up at and where does thepvc valve hook too? in all the picture of yalls truck i have never seen any of yalls hooked up this way any help would be great thanks, john
willow72 is offline   Reply With Quote
Old 03-12-2005, 09:40 AM   #2
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
Don't know if you have a real problems or not? Your brake booster should hook to your intake and the pcv line to your carb. This way the fumes that are created in your "motor" are mixed with the incoming air and reburned.You might also have a line from a charcoal canister that tee's into your pcv line.
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 03-12-2005, 10:34 AM   #3
krue
Designated A-hole!
krue's Avatar
If it were me I would try to make sure the booster had it's own source of vacuum.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-12-2005, 03:45 PM   #4
70 shorty
Where's my beer?
70 shorty's Avatar
I've also gotten the same advice, the brake booster needs a dedicated source of vacumn. It makes sense, you'd hate to find out your brakes weren't up to snuff at the worst possibel time.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 03-12-2005, 04:09 PM   #5
72MARIO
72MARIO's Avatar
Brake booster should have a fitting in the intake. Check any old intake it will have the fitting you need.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-12-2005, 04:09 PM   #6
gefs55
Just got done doing the same with mine had a tee placed on the back of my demon. The truck does seem to run fine how it is setup. I have another vacum port on my intake manifold and will change to that to have a dedicated line for the brakes when it gets warm. Do you have any problems with your demon running rich when the engine is cold?
gefs55 is offline   Reply With Quote
Old 03-12-2005, 06:17 PM   #7
willow72
willow72's Avatar
i did have a problem with the demon running rich when cold demon techs had me drill out my air bleeds a little larger which was verry easy contact demon tech thy are very helpful,john
Old 03-13-2005, 12:33 AM   #8
gefs55
Thanks for the help on the demon I will give them a call.
