Old 03-13-2005, 01:59 AM   #1
Mcgwirejh
Gear Ratio Help?
canyone tell me what gear ratio i got in my glove box on the parts id its says rear axle-standard?
Mcgwirejh is offline   Reply With Quote
Old 03-13-2005, 02:23 AM   #2
Gyva
Gyva's Avatar
break open the diff case it'll be stamped on the ring, best way to check incase someone has swapped them already on ya..
Mike
Gyva is offline   Reply With Quote
Old 03-13-2005, 11:36 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
If you open the diff, you can count the teeth on the ring & the pinion - divide the ring by the pinion and that's it. Or just jack up the back of the truck and rotate a tire one full turn while counting driveshaft revolutions, and that's your gear ratio. Unless you have an open diff - in which case you multiply the shaft revolutions x 2. Or rotate the tire twice.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-13-2005, 12:53 PM   #4
Truckstuff
Truckstuff's Avatar
Mike
Heres what your looking for. Just divide. This one is 3.727 (3.73)
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 03-13-2005, 11:53 PM   #5
Ratpowerd67
is that carrier chrome plated, or is that just the way the pic turned out?
Ratpowerd67 is offline   Reply With Quote
Old 03-14-2005, 12:02 AM   #6
Truckstuff
Truckstuff's Avatar
Its just the way the pic turned out.
1985 GM K3500 3+3
1981 GM K2500 SSB
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
