Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 03-13-2005, 07:55 PM   #1
69 air cab
paint runs.....how to repair?
Well I did some painting on the old 69 today and have some paint runs. Do I I just sand it back down in that area or what?
69 air cab is offline   Reply With Quote
Old 03-13-2005, 08:17 PM   #2
Randy70C-10
Randy70C-10's Avatar
Are the runs all over it? Did you use low-temp reducer? If you used medium or high temp reducer that would explain the runs. You should wet sand the runs out with 400 grit and warm soapy water and re-shoot, but reduce this coat just a little more (thinner) this time and use fast-dry reducer (low temp).
Randy70C-10 is offline   Reply With Quote
Old 03-13-2005, 08:24 PM   #3
cdowns
cdowns's Avatar
it really depends on the type of paint used
Old 03-13-2005, 08:46 PM   #4
Orange70chevy
Orange70chevy's Avatar
If it is a clear coat you can use a razor blade to scrape them out then sand and buff.
Orange70chevy is offline   Reply With Quote
Old 03-13-2005, 11:07 PM   #5
HuggerCST
HuggerCST's Avatar
They make small scrapers just for this to "carve" out the run, Bill. Then you will have to buff it, of coarse. If it has a clearcoat, and the runs are in the clear only, then it isn't that hard to fix. Personally, I would sand them out with 1200 or 1500 grit wet paper and a sanding block, then buff it back to a shine, but there are several different ways to do it. If it is a single stage paint, I would recomend resanding/spraying, but then again, I'm no professional.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-14-2005, 11:28 AM   #6
72K10
Best way is to catch them when they are still wet. Use masking tape to lift them off, let tack dry, then spray light again. No run.
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 03-17-2005, 07:42 PM   #7
69 air cab
Thanks too all of you for your input. Hugger, I was hoping you would not see that I messed up........ha.........now I will have to tell you the whole story when I see you.
