Old 03-14-2005, 12:51 PM   #1
greenvilledave
clutch shaft question
I know this question has already been asked but I need to know how to make the clutch pivot shaft work when I have changed from a 250 three speed to a 350 with the three speed. The 350 does not have the casting or the bolt holes for the pivot ball thanks dave ps pictures would be great
greenvilledave is offline   Reply With Quote
Old 03-14-2005, 01:39 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
I ran into this problem one time. The ball screws directly into the block. I had to drill and tap the engine block. Scarry stuff.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-14-2005, 03:23 PM   #3
greenvilledave
i don't remember but is there a large enough part of the casting to drill and tap that is accross from the frame point thanks dave
Old 03-15-2005, 07:29 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
yes..Its right by the dip stick...if you have a driverside dipstick motor.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 03-15-2005, 09:34 AM   #5
greenvilledave
ok I look at that last night by the way oldchev4x4 thanks for the help there is a casting that is threaded right accross from the frame point. Since I am not going to use the original six cylinder setup ever again can i take apart grind and thread one more thing the clutch shaft seems to be pretty close between these to points. then my son and i started to fit the headers into this area might be a problem thanks dave
Old 03-15-2005, 01:13 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
I had to screw the ball in, then install the header , then install the Z bar clutch linkage. The arm on the Z bar would hit on the header when the clutch was pushed in, so i cut it off and welded it on where i needed it. Hope this helps.
I think the ball is different for a V8.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
