03-14-2005, 09:16 PM | #1 |
Location: biwabik, minnesota, what is this white stuff out here
10 bolt or 12 bolt
ok yall, heres another one for ya, been thinkin about this for a bit, i know i should know the answer to this just by takein my rear end cover off and looking, but im asking here first, what come stock in a 70 1/2 ton 2 wheel drive, in the rear end that is, is a 10 bolt or a 12 bolt that is in it, im thinkin about changeing out the gears becuase it runs to high on the road for me, even running at about 55 it still seems a bit high, im pretty sure that some one has changed it out before i got it, but im just wonderin what is stock in it, that way i can go from there, and then when i pull the cover, i will see which way they tryed to go with the truck,,,,,,thanks in advanced,,,,,,,mark
03-14-2005, 09:20 PM | #2 |
I vote 12. Not based on any reference of credibility whatsoever. Just count the cover bolts, it that simple.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
03-14-2005, 09:39 PM | #3 |
Yep stock came with a 12 bolt.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
03-14-2005, 09:38 PM | #4 |
so by going out and countin the cover bolts ill be able to tell if its 10 or 12??????
03-14-2005, 09:42 PM | #5 |
so when ppl talk about a 10 or 12 bolt thats how many are on the cover and not what holds the gear together then?
03-14-2005, 09:57 PM | #6 |
Watch out for your cornhole !
No, it is the number of bolts that hold the ring gear to the carrier. When someone talks about 10 or 12 bolt, it is technically not the cover bolts you're talking about.
Coincidentally, though, 99.something percent of GM rearends have the same number of rear cover bolts as ring gear bolts. Some mid 60's GM cars though, did have a 12 bolt cover and 10 bolt ring gear internals. So, it's not always the same. A 70 model truck had a 12 bolt stock though. Ten bolt rears came later in trucks.
03-15-2005, 08:00 AM | #7 | |
That is an old wives tale. It is the number of bolts on the cover. "14 bolt" axles have 12 bolts holding the ring to the carrier. GM never used this terminology in any way - they refer to the axles by ring gear diameter.
Tim |
03-14-2005, 10:09 PM | #8 |
thank u every one for the help, now i can go and take a look at which way i want to go with the rear end, and about how much im gonna spend for the gears, thanks again
