Old 03-17-2005, 02:33 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Bolt removal
How do you remove the lower panhard bar bolt from the differential after the bar is off? Does the bolt have a sleeve for the bushing to ride on. I dont care about destroying it because it is getting replaced with super trac bar from Early Classics
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 03-17-2005, 05:10 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Remove the big nut from the front of the differential housing and give the stud a twist with a pipe wrench. It will pop right out.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
