Ok my question is the 60-87 Front bag mounting brackets the same?
The first is from http://www.streetissuecustoms.com it sayes 60-87 The second is from Jason at http://www.***************** they say 67-87 What’s the deal will Jason’s work? I would rather get them from him. |
Oh ya I have a 66 c-10 long bed
Project92 SWB stepside
Just ordered a 8" notch from Jason and it is top quality!! FAST shipping!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
Never Done?
![]() Join Date: May 2000
Yes, either set will work on any 63-72 1/2 ton.. not sure about the bigger stuff. But there's your answer. I say this because I have plates and cups from both ***************** and AirRide Technologies, and the plates both bolt up the same, and AirRide lists them as 63-72 C10. Take that for whatever it may be worth.
so it is a go to get it from jason?
his sh## is awesome THANKS, |
Head Peon
![]() Join Date: Dec 1999
If you ordered from Doug at StreetIssue you would most likely end up with SD stuff anyways since he is a SD dealer
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4 |
#7 | |
Shortbox wanna-be.
Yes, get them from him. I bought mine from him and they are top quality items.
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) ![]() |
lol thanks
hey guys on those lower cups, did yall cut them down any. i ordered some and they seem really tall and i was wondering if there is any need to shorten them to get my truck to lay out. thanks. oh and mine are from suicidedoors also.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
Epoxy Primer Friendly
Im trying it without them as suggested by a few and my LCA bumpstops are gone.
Needs a Big Block
I built my own in a very short period of time using a hammer some C clamps and a grinder , and drill press, tonight , I removed my bumpstops from my a arms , I as well will be trying it with out bottom cup, I guess we'll see how that works out.
I have heard great things about the SD brackets and all his product for that matter
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
let me know how that works out i orderd all may stuff last week
sold
i have the sd cups and i wish i had cut them a little before i put them in
are they a little bit to high or what. im just curious because my truck doesnt lay as it is so i at least want my lower arms on the ground. thanks
#15 |
i'm ressurecting this old post. how much if any can be cut off the bottom of the cups?
#16 |
I can look tomorrow to be exact, but I think it is about .75-1" that can be taken off the SD bottom cups.
Using the Airlift bags I am going to run w/o cups and see what happens, if they seem to rub too much I will modify the cups and use them. |
#17 |
any one fined out how can be cut off the bottom of the cups?
Atom (bigRed66) 1966- C10 1995- Wide Body Talon 1987- Dodge Raider (4 sale) 2000- 4-door Nissan Frontier 2003- Ford Focus (wife) |
#18 |
I have sd cups and cut 1.75 off and lay on 20s witha 275/45 tire. overall dia of about 30ins.
#19 |
thats also with 3in drop spindles and 3 1/4 "z" in the frame
#20 | |
#21 |
Does any one have the exact dimensions of the top plate that mounts on to the crossmember. I had some xtra metal that I will not be needing so why not save a buck and make my own top brackets. Need to move my truck quick cuz this freak landlord decided to sell the house early.
#22 |
I can still measure them, but with the SD top plates and no bottom cups, I am on the A- arms and very close to the crossmember (less than 1/4") deflated.
![]() ![]() Last edited by pbmcauliffe; 05-04-2005 at 12:24 AM. |
