Old 03-23-2005, 12:50 AM   #1
HatGuy
HatGuy's Avatar
Question How Tall
What is the tallest tire that will fit my 72' k5 4x4 with stock ride hight?
I'm considering 265/70/17 tires that are 31.7" tall.
What do ya think?
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 03-23-2005, 03:02 AM   #2
JBstor
JBstor's Avatar
I can't give you a definite, for certain answer, but I had 12 x 33's on mine for about a week before getting the springs redone, and had no problems.
I don't know if you have a 2x or 4x, and "stock" height after 30 years can vary, I am sure, if you catch my drift.
I would imagine you would be OK, but if you really want to find out for sure, do some serious measuring, compare the tires you have now to what you want, and add that on with the wheels turned, that is usually the biggest problem, turning.
HTH
JB
JBstor is offline   Reply With Quote
Old 03-23-2005, 03:41 AM   #3
71jimmy
71jimmy's Avatar
Go here for a tire fitment guide on CK5, http://www.coloradok5.com/tirefitmenttable.shtml
That's just for reference. Personnally I think you can get away with 33s without a lift if you do very minimal off roading. I currently have 31s with no lift and have plenty of clearance for all kinds of wheeling. From reading posts for the last year or so I get the feeling that there is no definative. What works for one may not work for someone else necessarily.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 03-23-2005, 09:57 AM   #4
crispy
'71 Chevy Blazer
hat guy. i have 33x9.5x15 on my '71 k5 with no lift. i think i could fit 33x12.5x15 with no problems and when the 9.5's wear out i will be looking for a set of the 12.5's.
'71 K5 Blazer (new project / daily driver)
"If you are not working to improve the situation, you have no business complaining"
crispy is offline   Reply With Quote
Old 03-23-2005, 10:05 AM   #5
MikeS
Active Member
MikeS's Avatar
I've got 33X12.5's on mine. When I bought it it had the orginal springs in it. Never a problem on road, but off road, the fronts would rub on tight corners. 33X9.5's would probably be fine but I opted for a 2.5" lift from Skyjacker. No problems then.
Mike
MikeS is offline   Reply With Quote
Old 03-23-2005, 12:03 PM   #6
TRUCKPOOR
265/70/17 is a stock tire size for 2005 GM 4x4 truck and suv. Are you thinking of using a set of 'take offs'? The center offset of a rim will be a big part of how wide and tall you can go without a lift.
TRUCKPOOR is offline   Reply With Quote
Old 03-23-2005, 12:53 PM   #7
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've seen photos of one with 38's on it - of course, there was a lot of trimming.
I think you need to get the centers of the wheels machined out to fit over the hubs also...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-23-2005, 09:17 PM   #8
HatGuy
HatGuy's Avatar
I'm looking at 59 Series - GM K-10 (4th one down) on this site
http://www.stocktonwheel.com/light_truck_wheels.htm
they say the can make a 17" Ralley wheel with the whatever
offset you need.
Tires are still undesided. Thake offs might be a good Idea
72' K5 Highlander
My Daily Driver
Old 03-26-2005, 06:59 PM   #9
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I run 32x11.50 on my stock height worn out blazer spring's and they dont rub or anything like that...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-27-2005, 01:17 AM   #10
HatGuy
HatGuy's Avatar
Thanks, FrenchBlue72
Thats good to here.
I'm looking at 31.7X8.5
72' K5 Highlander
My Daily Driver
