Old 03-24-2005, 01:07 PM   #1
nyncompute
nyncompute's Avatar
A/C Freash air question
I am working on the A/C heating system, and after removing the cowl ,I saw this little set up. I assume this flap is supposed to open via the metal lever. Qustion: What connects the lever to the door. What sort of clip / connector is used (besides bailing wire).
nyncompute is offline   Reply With Quote
Old 03-24-2005, 01:17 PM   #2
Custom 68
Custom 68's Avatar
Alright if I remember correct the metal rod and spring in your picture is just there to keep it in the firewall and let it rotate. The spring keeps it engaged. The lower arrow to the hole gets a spring to keep this open. On the outside not shown in the photo sticks out of the cowl into the engine compartment on this goes another rod that gets attached to a vacumn pot the levers inside the cab operate the vaccumn that opens this one and closes the vent on the passengers side this is the same as the "recurculate" when the outside vent is open the inside closes this uses fresh air...
clear as mud? I can get some picture of my setup if you need. I am sure there are others that may clear this up.
DAve
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-24-2005, 02:44 PM   #3
nyncompute
nyncompute's Avatar
Ok I think I see. So the spring goes from the lower arrow hole to ????
Old 03-24-2005, 02:57 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Yes. Here is a pic of the vacuum pot
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 03-24-2005, 03:37 PM   #5
Custom 68
Custom 68's Avatar
it goes to the hole right below the 3rd windshield wiper looking bracket in CPNE's picture. It just hooks somewhere to keep it open prior to vaccumn being applied...
Dave
Old 03-24-2005, 04:08 PM   #6
nyncompute
nyncompute's Avatar
Ok so there is a spring..it goes through the hole to where? should I lay off the pipe a little? (I have the whole firewall stuff complete thanks CPNE)
Old 03-24-2005, 04:16 PM   #7
Custom 68
Custom 68's Avatar
my post above was intended to answer that... the spring will go up from what you are showing to a small hole in the non used windshield wiper brace. I dont think I can edit the picts but may try.
Dave
Old 03-24-2005, 04:18 PM   #8
Custom 68
Custom 68's Avatar
look here
Dave
Old 03-24-2005, 06:27 PM   #9
nyncompute
nyncompute's Avatar
I get it.. I relate to pictures better than the written word
Old 03-24-2005, 08:24 PM   #10
JimKshortstep4x4
Here is a pic of where the spring hooks up.
Jim
