Old 03-24-2005, 07:10 PM   #1
Dano69c10
Dano69c10's Avatar
69-72 swb on a 73-87 swb frame?
A friend wanted me to ask you guys if a 69-72 swb truck can be transplanted onto a 73-87 swb frame. Are the wheelbases the same and are the cab/rad support mounts the same or would they have to be repositioned?
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 03-24-2005, 07:30 PM   #2
67cst
i love summertime
67cst's Avatar
hey dan, ive tried this and it doesnt work, the frames are different, as in the rails start angling up sooner on the later year frames and the cabs dont sit flat. trust me it was a major headache and i finally gave up, get the right frame and everything will bolt on...just my 2 cents
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 03-24-2005, 11:50 PM   #3
Dano69c10
Dano69c10's Avatar
My friend was not happy to hear this, he has a 73 swb frame he bought today. I told him not to buy it until we found out, but...
Dano
'69 Fleet
Old 03-25-2005, 12:20 AM   #4
72 CustomCamper
huh ???
72 CustomCamper's Avatar
PM Mudder67, his truck is on a later model frame. I'm sure he can walk you and your buddy through what has to be done...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 03-25-2005, 07:57 AM   #5
Mudder
Mudder's Avatar
Mine is a 4x4 and I used a body lift. Knowing now what I didnt know then is I could have gotten by with less body lift.
Mudder is offline   Reply With Quote
Old 04-25-2005, 09:33 PM   #6
jamal
jamal's Avatar
Me and my father in law have run into a problem, he has a 71 chevy with a wheelbase of 117.5, but it shows they came 115. It was a long wheelbase that has been cut, bed, frame, and all was cut to make it work. It looks great but he dont trust the welds, and wants to swap to a 73 up frame which is also a 117.5 wheelbase. The truck looks great been painted and all, looks good so changing the bed to a correct length swb bed is not an option. the question is what all is needed to make this work?
jamal is offline   Reply With Quote
Old 04-25-2005, 09:52 PM   #7
Mudder
Mudder's Avatar
PM me your email addy and I can send you some info on how I made mine work. (4x4 only)
Old 04-25-2005, 11:32 PM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
If you do the welds right (like a Z-pattern in the framerail) and weld some plate steel on both sides it will be plenty strong.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 04-26-2005, 07:07 PM   #9
jamal
jamal's Avatar
I think we are just going to fish plate it (weld plates to it) Do you think it would be strong enough to weld them in the inside only? The welds on outside have been ground down and from the outside you cant tell it
Old 04-26-2005, 08:16 PM   #10
chief bobber
Sanity is a state of mind
chief bobber's Avatar
Yes, a fish plate on one side will work, but do not weld a continous bead all around. stitch weld it(1"weld leave a few inches, another 1" weld leave a few). I like to start at a corner and weld 1" up and 1" over. I nail all four corners and stitch in between.
Good luck.......
67 K-10 8ft step 250/465/timken 4 shaft/373 to 1
70 C-10 Panel Vortec V/5spd BW od /307 to 1
70 C-30 9ft stepside dump 350/465/ posi
and a few too many other trucks, cars, jeeps, cruisiers, and M/Cs
...o~`o
chief bobber is offline   Reply With Quote
