Flamin' Bass
Seam sealer
I posted this question in the Paint and Body forum 2 days ago. It got 11 looks, 0 replys so I'm trying it here because I know someone here has an answer.......
My '67 C-10 cab is finally down to bare metal. Finished all patch welding (all floors, rockers, kicks, front pillers and corners, whew!) and sprayed on a see thru coat of 2K epoxy to limit rust until the plastic work is done. I've asked a few 'experts' about when I should replace the seam sealer (especially in the drip rails): over bare metal? over the epoxy? over the 2K urethane primer filler I hope to spray next week? Got too many answers, not sure if any of them are right. Can someone who's BTDT offer advice?
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
Registered Cruiser
You will have the best results if you primer coat over the body caulking. For the question of application over bare metal vs. a primed surface. I prefer a primed surface. It's easier to apply, as well as see what you are doing. Once you're satisfied with your results coat it well with primer paying attention to any fisheyes that might occur. Any imperfections could possibly show in your finish paint. Good question I hope this helps.
I intend to live forever. So far, so good. |
starting at the bare metal......
1.) etching primer 2.) seam sealer 3.) sealing/ hi build epoxy primer 4. ) top coat hope this helps....... |
