03-27-2005, 12:54 AM | #1 |
Front sway bar mount
My Brother has a 70 K-5 that has had just about everything replaced at one time or another in the past few years. Converted to disc brakes up front, new springs all the way around, rebuilt rear end, newer transfere case, rebuilt 4 speed, new motor also. Anyway, he has a front sway bar off my old 76 K-5. Will it work on his Blazer? Also Does anyone have the Spring mounts that it bolts to? Any info is appreciated. Thanks.
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
03-27-2005, 01:00 AM | #2 |
Just like to part out trucks!!
It will work but you will have to fab up some frame brackets for the front part of it. BobbyK built some brackets for his. Look on the FAQ board on the 2nd page, and you will find Bob's thread.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" Last edited by teeitup; 03-27-2005 at 01:04 AM. |
03-27-2005, 01:03 AM | #3 |
Here's the link to it. Thanks to BobbyK, really nice job!
http://67-72chevytrucks.com/vboard/s...highlight=sway
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." |
03-27-2005, 02:31 AM | #4 |
Thanks guys. That BobbyK really does some nice work. Will the spring pads off any of the 70-80s 4X4s works on his Blazer?
03-27-2005, 10:52 AM | #5 |
PROJECT 7DEUCE
All the spring pads should be the same as far as I can tell.. The 3/4 ton and up trucks may have different pads..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
