03-27-2005, 08:09 PM | #1 |
Randy churchill
Parting out 72 C20
I have a 72 that I am going to part out. Most of the front sheetmetal is dented beyond repair. The turck has a 4 speed and a 8 lug 10 bolt rear with 4.10 gear ratio. Just post what your looking for and I will post a pics and a price for it.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires 2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10 2003 Jeep Rubicon 4.5" short arm lift 1985 Jeep CJ7 30k in parts and still adding up |
03-27-2005, 09:40 PM | #2 |
Car O'Holic
Cab Doors Seat Bed Brake Booster?
03-27-2005, 10:31 PM | #3 |
Randy churchill
I will sale the whole truck for $500 or $350 without the vin & Title. The truck is beat up from being a ranch truck since it was new. Until 4 months ago when the engine was pulled.
03-28-2005, 11:30 AM | #4 |
Is the rear end an eaton or dana. I am looking for an eaton 10 bolt 8 lug 4.10
03-28-2005, 01:00 PM | #5 |
II Timothy 4:2
PM Sent
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus" MY TRUE PRIDE AND JOY "Dangit, Bobby, people will see that oil stain and think I'm a drunk." |
03-28-2005, 01:11 PM | #6 |
Randy churchill
On the rear I am not sure, whats the difference? This is the first 10 bolt 3/4 ton axel I have delt with.
03-28-2005, 02:05 PM | #7 |
I am pretty new with this to ,but they say you can remove the whole center section, it unbolts on the driveshaft side of the rearend
03-28-2005, 02:21 PM | #8 |
67-72 Addict!
Is the grille good?. If so how much shipped to 21236?. Same for the headlight bezels. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-28-2005, 04:14 PM | #9 |
Randy churchill
On the rearend just the cover unbolts.
03-28-2005, 06:34 PM | #10 |
Randy churchill
The grill is good for a driver, its been repaired in one spot and has scuffs. The inner grill looks good with a few cracks. The complete grill with headlight buckets $175. plus shipping, I'll have to get a box and weight. If you want it I will pull it off and get a shipping qoute.
03-28-2005, 11:56 PM | #11 |
67-72 Addict!
Randy, I'm going to pass. Thanks
03-29-2005, 12:20 AM | #12 |
Any of the wiring harnesses. Need engine harness (V8). Cab harness (no A/C). Tail Light harness.
Scott |
03-29-2005, 12:23 AM | #13 |
Senoir Member
How about the power brake setup (without master cylinder).
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
03-29-2005, 12:43 AM | #14 |
Randy churchill
Scott I will sale the whole wiring harness for $100 dollars shipping is included for that price.
Greg on the power brake setup, do you just want the boster?
03-29-2005, 07:18 PM | #15 |
Senoir Member
I need the booster, any brackets, nuts/bolts, hose to engine, & rod to pedal. Would also be interested in the brake lines from the master cylinder if they disconnect on the frame below. Also need rear bumper brackets with nuts/bolts, and the throttle cable & pedal. Let me know.
03-29-2005, 07:26 PM | #16 |
Car O'Holic
Hows the cab? is it useable any dents major dammage? and how are the rockers and kick pannels? any pics of that?
03-29-2005, 11:41 PM | #17 |
Randy churchill
Greg I don't have rear bumper brackets, Everything else I might can I'll let you know on a price after I get them off.
striker169, the cab has some damage right above the windsheild on the drivers side. The doors are in good shape the rockers are rusted and so is one cab corner. All the floor suports are there and look to be in good shape. I will post pics tomarow. I'll take $300 for the cab & doors with all the glass or $350 for it with vin & title.
