Old 03-28-2005, 12:13 AM   #1
krue
Designated A-hole!
krue's Avatar
Is it safe
to take the top off of my Blazer? Will I be able to get it back on? What are some good options for a soft top?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-28-2005, 03:03 AM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Specialty Top Co and Bestop both make soft tops. Your sig says "RUST BUCKET" - How much rust are we talking? Are the rocker boxes and windshield solid? If you take it off and can't get it back on, you can always buy a soft top then (be warned, it takes about 6 to 8 weeks for the specialty Top co tops to arrive after you order it.) You could weld a cage in place to maintain the rigidity of the body and then take the top off.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-28-2005, 09:54 PM   #3
Paul72
Paul72's Avatar
I take my top off and my doors rattle when I hit bumps. I have no rocker boxes, and my doors close hard. The top goes back on without any problem.
As far as being 'safe', just don't roll it!
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 03-29-2005, 12:52 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If the floor and boxes are solid you should be fine if you have any doubts dont do it..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 03-29-2005, 01:03 AM   #5
krue
Designated A-hole!
krue's Avatar
solid? What's that?
www.daveramsey.com
Old 03-29-2005, 09:02 AM   #6
Huck
Huck's Avatar
Just be sure to remove the bolts that go through the sun visor brackets to the top as a lot of guys mis that!!
Huck is offline   Reply With Quote
Old 03-29-2005, 08:17 PM   #7
thekidd
thekidd's Avatar
I KNOW I KNOW but it won't happen again!! I've learned my lesson. Not planning on putting top back on anytime soon.
thekidd
95 Silverado
2000 Suburban 4x4
91 Nissan 4x4
65 Impala SS (Mom and Dads now mine)
1971 K5 Blazer(Father and son project)
1972 2WD Blazer
thekidd is offline   Reply With Quote
Old 03-29-2005, 08:32 PM   #8
moodyholler
moodyholler's Avatar
I had a 69 in 1980 that we had to set a jack under the panels every fall to get the bolts back in. I sure had a ball in that old rust bucket. Found a picture of it and scanner isn't working. Will post when I can. Moodyholler
1998 WRANGLER I-6 auto
1972 LWB FLEETSIDE
1968 GMC SWB STEPSIDE
1994 C-1500 SWB 4.3 5 SPD
moodyholler is offline   Reply With Quote
Old 03-29-2005, 07:04 PM   #9
Big Block
Big Block
Big Block's Avatar
I had a 71 rust bucket, took off the top and the drivers door was very hard to close. After further inspection I found the body mount behind both doors were rusted out and the rubber mounts were almost completely gone. I just used the passenger door to get in and out until I put the top back on. Didn't keep that Blazer to long after I found all the rust and bondo in it. I learned what to look for before I bought my current 72 CST Blazer. It is rock soild but I had to shim the passenger door latch so it won't bind when it is closed. B.B,
Big Block is offline   Reply With Quote
