Old 03-28-2005, 12:51 PM   #1
Rod
whats the value of a nv4500 4wd tranny?
Anyone got a typical idea of what a nv4500 tranny is worth from a 90's 4x4 Chev. And would a diesel one ( tranny) not work for our era? I think it should work as long as a 6.5 originally.
Lets say a value with clutch and flywheel and original bellhousing though it would be hydraulic style on opposite side necessary for a nv4500 swap like ryanroo.
And what is it with my reading use a dodge bellhousing... does it bolt up to the chev block and tranny? Or does it only just have the correct side port hole for manual clutch linkage?.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 03-28-2005, 01:22 PM   #2
soulman67
Randy churchill
soulman67's Avatar
The diesel nv4500 will work, I set up a 67 1/2 ton with a 454 and a nv4500 but after I was ready to install the tranny I found out my brother sold the tranny. I used the clutch stuff from the 93 I got the tranny from. I believe you can go to a parts store and order the whole hydro. assemble for about $150 dollars.
1983 GMC K2500 6.2 diesel 4" lift on 35x12.50 tires
2008 GMC 2500HD 6.6 diesel 3" lift on 315 75 16X10
2003 Jeep Rubicon 4.5" short arm lift
1985 Jeep CJ7 30k in parts and still adding up
soulman67 is offline   Reply With Quote
Old 03-28-2005, 01:25 PM   #3
soulman67
Randy churchill
soulman67's Avatar
The NV4500 normally goes for over a grand arround where I live, my brother sold mine for 150 dollars.
Old 03-28-2005, 01:36 PM   #4
Rod
Started watching auction on ebay for these and saw this..but Im not sure what it is but 300 bucks? seemed odd.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
Old 03-28-2005, 01:44 PM   #5
soulman67
Randy churchill
soulman67's Avatar
That trans was a Nv3500, which can be found cheap. They can't handle as much power and torque as the nv4500. But if you have a mild to stock engine a nv3500 would be a better chioce cause they are lighter than the nv4500 and a lot easier on the wallet.
Old 03-28-2005, 04:57 PM   #6
Rod
That tranny just didn't look right....so I suspected something....he listed it as a 1999 1/2 ton 4x4 tranny. Maybe it was in the box.....someone might not be happy when they get it. That aint right....scam
