03-29-2005, 05:00 PM | #1 |
BB Power steering reservoir hose
I have a 70 C20 Big Block truck with the remote steering reservoir. The hose to the pump was replaced with what looked like heater hose when I got the truck. I have since replaced it with new 3/4 heater hose. Does anyone know if the original hose is reproduced or where I can find the correct replacement?
Thanks in advance
Larry 1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green" 1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red" 1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon" 2005 VW Beetle Diesel 44+ MPG "Silver Bullet" |
03-29-2005, 07:12 PM | #2 |
Mine Is Heater Hose...
https://www.ebay.com/itm/29620574751...mis&media=COPY |
03-29-2005, 09:13 PM | #3 |
its all about the +6 inches
heater hose will work, but it isn't a good idea. you can get the right stuff at napa.
03-29-2005, 10:08 PM | #4 |
Out draggin'
I was going to try Danchuk or some other vendor that caters to the Chevelle crowd. The remote reservoir is the same on them...
91 GMC Xcab LB-Bags/bd/caddy clip SOLD 72 C10 Cheyenne Super LWB SOLD 92 GMC K1500 Burb 72 C10 Burb (ex. Cheesewagon)SOLD 72 C20 Burb parts truck 71 C10 Burb "project" |
03-29-2005, 10:18 PM | #5 |
I thouht it was heater hose just used...has some lines grooved the length of it unlike newer hose. Might still be available, never looked for it. Had lots of older cars with heater hoses that looked same.
03-29-2005, 10:22 PM | #6 |
Heater hose is not rated for oil. Try some hydraulic hose, you can buy that in bulk at napa.
03-29-2005, 10:44 PM | #7 |
Go Vols
Try Gates LOL Plus hose, it' designed for low presure oils and fluids. Should be available at local parts stores.
When you have to shoot, shoot don't talk. |
03-30-2005, 05:07 PM | #8 |
Thanks for your ideas. I don't like the idea of using heater hose and it collapses when it makes the sharp bend required to get from the reservoir to the pump. I'll try NAPA.
03-30-2005, 05:25 PM | #9 |
Original parts group has the hose. Part number is CH20278. $25.45 each.
Pricey but correct. I just looked it up for a Chevelle big block. Thanks for the help everyone!
