03-30-2005, 01:28 PM | #1 |
Right rear wheel locking up
Last night I hit the brakes and the right rear tire locked up on me. None of the others did just the right rear. Why would it do that? I wasnt hitting the brakes hard enough for a lock up.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
03-30-2005, 01:33 PM | #2 |
Resident Curmudgeon
Shoe adjustment? Or bad wheel cylinder
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-30-2005, 01:50 PM | #3 |
Probably wheel cylinder knowing my luck I jsut replaced a wheel cylinder on the front a few months back. Maybe its time for a full truck brake job new wheel cylinders, shoes, drums, hardware kit the works.
03-30-2005, 04:26 PM | #4 | |
Questionable
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-30-2005, 04:29 PM | #5 | |
03-30-2005, 02:43 PM | #6 |
I agree with the wheel cylinder. A little bit of brake fluid on a shoe will wake you up in a hurry.
Silence is golden, duct tape is silver. - Scott |
03-30-2005, 08:41 PM | #7 |
Franko72
wheel cylinder blown.I always change one and not the other ,some times its good sometimes twice as bad
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
03-30-2005, 09:58 PM | #8 |
Location: Help! I'm in an office park with its own network of freeways!
Your e-brake cable on that side could be seized. Same thing happened to me a couple years ago.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
03-30-2005, 10:01 PM | #9 |
68cst_ss490
leaking axle seal is my bet.
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
03-30-2005, 10:05 PM | #10 |
Got Light Emitting Diode?
i would say the master cylinder is bad. so is the prop valve. the wheel cylinder could stand a replacement. while you are in there you might as well do the axel seal........oh sorry
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
03-30-2005, 10:19 PM | #11 |
cantontruck
Mine did that about a month ago. It was a bad wheel cylinder.
03-31-2005, 08:53 AM | #12 |
1969 Custom 30 wrecker
Mine did that when I had an emergency brake cable keeping the brakes on a bit. After driving a while, it would heat up and get very sensitive. Just touching the brakes made that wheel lock up.
Next time it happens, pull over and carefully feel the drums. If that wheel is alot hotter, that's most likely your problem. Bob
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
