Old 04-02-2005, 06:17 PM   #1
dylan1970
dylan1970's Avatar
I'm an Idiot
I hate to do this to you guys again but, I've been trying to find a good quality wiring and plumbing diagram for the rear air ride suspension on my truck. I just got my compressor kit and air bags and now I'm just trying to figure out how I'm going to mount and wire everything up. My kit is just for the rear and it only goes up and down (not side to side). If any of you can help me out I would really appreciate it. Thanks in advance.
dylan1970 is offline   Reply With Quote
Old 04-02-2005, 06:33 PM   #2
KdawgS10
keller
KdawgS10's Avatar
http://www.bagginit.com/basics.html
83 1ton 4door dually, 350/700r4
99 S10 2.2/5speed bagged. traded for the dually
91 S10, 2.5/5speed juiced
87 3/4 4x4, 350/4speed
89 S10 long bed , 2.8/5speed
65 chevy short bed stepside, 327/3speed
97 neon acr, 2.0 dohc 5speed DD
KdawgS10 is offline   Reply With Quote
Old 04-02-2005, 06:34 PM   #3
bagged72blaz
Got L.E.D.s
bagged72blaz's Avatar
I'm assuming you have one fill, and one dump valve for the rear only correct? If so you just need a two way momentary toggle switch. Ground the negitve wire of the valves to the chassis, and run the positive wires to either side of the three spades coming off the toggle and wire a positive wire from iginition source to the middle terminal of the toggle. Line from compressor to check valve then to tank, from the tank will go into the fill valve and then out of the fill valve into a T and then Y'd to the bags from there. Then go back to the T and install the dump valve. I also like to install some type of safty toggle hidden to kill power completly to the system. When working on your rig, or when parked.
Bagged 1972 2wd Blazer
http://www.earlyclassic.com/home.aspx
bagged72blaz is offline   Reply With Quote
Old 04-02-2005, 06:40 PM   #4
dylan1970
dylan1970's Avatar
Thanks for all the info! This will help me out alot. The safty swich is a great idea, so now all i need is that.
Old 04-02-2005, 08:48 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Take a look at this- Air bag diagrams
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
